Ticking noise with K&N
Old Feb 22, 2004 | 09:22 AM
pfbmgd's Avatar
I just installed a K&N filter on my 97 with a 2.7L .Now I hear a ticking niose from the right side of the truck when accelarating .It`s usually noticeable when low rpm 1500 to 2000 . Could this be detonation?
Old Feb 22, 2004 | 09:23 AM
934rnr's Avatar
Generally when you add a high flow air filter the AFM compensates too much fuel and it runs alot richer so I doubt it is detontaion that usually occurs from lack of fuel.
I would check your exhaust over it may have a leak somewhere like the manifold or attachment flanges.
Old Feb 22, 2004 | 12:03 PM
Fahrenheit 451's Avatar
Is this the filter charger kit or just a K&N filter still in the airfilter box? If it is the charger kit and you have the open breather element, you can expect some noise. I believe it even says so in the booklet/instructions that comes with the filter. You wind up with a straight shot to the plenum and you can hear the workings of the intake and valves more that way.
Old Feb 22, 2004 | 09:02 PM
pfbmgd's Avatar
I just installed the filter only .
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
