Thule racking up the runner...
Old Mar 28, 2003 | 08:51 AM
K guyz I need a quick answer here. I'm looking into buying a fit kit for my ma's old thule rack for the runner. In order to modify the old feet obviously a new fit kit is needed made for the 4 runner gutters. My question is are all fit kits made compatable with all thule feet. The kit includes the extension specific to runner gutters, but will they fit my old feet. If so great....it'll save me lots 'o coin, and speed up my racking by a few months at least. So lay it on me ......
Old Mar 28, 2003 | 09:25 AM
Babypig's Avatar
depending on the year of your runner you may need longer bolts for the feet. My 90 took a fit kit and longer bolts. I got them at rack attack on 5th or 6th in Vancouver.
Old Mar 28, 2003 | 09:50 AM
Firefyter-Emt's Avatar
Nomaly a "fit kit" will fit a Thule bar to the specific application... So, Yes.. BTW, the track used for the 4Runner is a very common one and fit's many rigs..
Here is a tip for you.. The stock sliding nut plates are way stronger than the "flip in" ones that come with the Thule rack, have at least 50% more grabing area and are threaded 6mm the same as Thules allen bolts.. Bottom line, remove the stock cross bars, bolt the Thule into the stock bolt plates... it will be alot stronger this way..
PS, the Thule ones also bent my tracks when I tightened them up because of how they grab the track...
Old Mar 28, 2003 | 10:26 AM
Thnx for das tips
Thnx for the tips guyz, I actually cruised on over to the thule web page, ran the make model year of my Ma's old toyota, and came up with the same foot serial number, so with a little educated guessing I figured they were the same feet, just different extensions. So, thnx for the low down on what to watch out for, eep, I'm not to keen on bending my gutters, gotta be careful there.
Old Mar 28, 2003 | 10:39 AM
jacksonpt's Avatar
Senior Member
Depending on how long you've had your gear, all fit kits are designed to fit a standard Thule foot. So when Thule gear is going from rig to rig, all you need to replace is the actual fit kit. At least that was the case 2+ years ago when I got my fit kit/feet/bars.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Scotttekoch
Sep 28, 2015 10:30 PM
dguzzi
Sep 3, 2015 08:48 AM
Medic22733
Aug 10, 2015 06:49 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
