Throttle position sensor help
Old Dec 16, 2004 | 12:14 PM
1987 street toy's Avatar
Question Throttle position sensor help
i tested the tps and on test 2 and 3 the ohm meter didn't move. test 1 is 500 test 4 is 6.0k and test 5 is 8.5k. can i adjust it or clean it or is the TPS toast?? if its toast where is the cheapest place to buy a replacement?
Old Dec 16, 2004 | 12:44 PM
RED 85's Avatar
What are the specks on you vehicle? i am parting out a 89 3VZE engine.
Old Dec 16, 2004 | 01:09 PM
spec.1987 22re
1 vta-e2, 200-800
2 idl-e2, <2.3k
3 idl-e2, open-infinite
4 vta-e2, 3.3k-10k
5 vcc-e2 3.0k-7.0k
this is what the tps read
1 500
2 meter did not move. open?
3 same as 2
4 6.0k
5 8.5k
is the Tps toast?? could this cause a crappy idle for a hour then run great other times? is $85 for a new one at napa a decent deal? Thanks for all the help
Old Dec 16, 2004 | 02:58 PM
Question
trouble code's 7 and 11
7. throttle position sensor signal- open/short
11. switch signal-neutral start switch ON (22R-E)or IDL point in throttle position sensor is off during diagnostic check
would i be right to say the TPS is junk??
Old Dec 16, 2004 | 03:11 PM
yotafreakshow's Avatar
Have you tried to adjust it yet? That will throw everything off if it's not set properly.
Check out: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Pull the EFI fuse for 10 minutes after you get it all set, that will reset the computer and CE light, unless it still senses a problem.
Old Dec 16, 2004 | 03:24 PM
no i have not tried adjusting it yet. How can you get the little philips screw loose without taking the throttle body off?
Old Dec 16, 2004 | 05:10 PM
Yamaha+Toyota=Fun's Avatar
You dont, you gotta remove the throttle body. I just unbolted it from the intake then unscrewed the bottom one. No need to drain the coolant. After that, put some allen's in instead of the phillips.
Old Dec 16, 2004 | 06:12 PM
yup...
crammit442
7
Nov 29, 2017 12:30 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
