Thoughts on Syn oil in gear/diff
Old Feb 23, 2005 | 08:58 AM
Alpine114's Avatar
99 4Runner, v6,5spd,...........havent changed gear oils, but took it off roading in some mucky mud/water, and most likely there is goop in the front/rear diffs. heard different things about cleaning them, and putting new oil in. Some said about spraying brake clean in them, to clean then, let new oil flow through, then once its clean oil comming out, cap it, and refill....let me know what you guys think...im new at all this, and i dont want to mess my truck up.
Old Feb 23, 2005 | 09:03 AM
GodwinAustin's Avatar
Definelty check your rear diff man - and if its got water check everything else and change them if necessary.
The rear diff is typically the first thing to suck up water - its pretty tough to get water in the front diff is the breather is real high and you would have probably sucked water into your intake before that.
Make sure you run the truck for a while to heat up the gear oil before checking it though.
You can get redline gear oil cheap and fast at http://www.myoilshop.com/
Old Feb 23, 2005 | 11:20 AM
Alpine114's Avatar
Godwin Austin, is that redline oil good stuff? havent heard of it actually. but i have heard good stuff with Mobile one....dont know...guys let me know whats up
Old Feb 23, 2005 | 11:30 AM
yeah man - I think quite a few people are running it in their rigs - search and you shall find.
bigjstang
Jun 2, 2025 03:56 PM
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
the1998sr5
Jul 16, 2015 06:20 AM
Edionne13
Jul 9, 2015 01:59 PM
