? for those who change their own oil
Old Oct 27, 2003 | 11:53 AM
INsr5runner's Avatar
Originally posted by Glenn
I used to have a Blitz drain pan and I hated it because the lid wouldn't go back on right and it leaked.
McMaster-Carr sells a nice one:
did you go with the 21" or the 18"?
Old Oct 27, 2003 | 12:39 PM
Gabe's Avatar
oil....
Take it to a Kragen Auto parts, they take used oil at no charge...
Old Oct 28, 2003 | 10:51 AM
Tacoma Dude's Avatar
I think I have the 21.
You may want to look to see if there's something better than that. The drain plug in the middle of the pan doesn't screw tight on mine. I used to have a drain pan much like this one but the drain hole had a large cap on it and the pan itself screwed into the hole for use and when not in used snapped tightly into where the drain is on the above illustration.
...but my roommate threw that one away
I might have gotten the one plug that doesn't work anymore but it's still definitely worth trying out before you buy - I mean unscrewing and screwing the plug to make sure you can get a seal and it doesn't do one of those gets tight then skips the tread and you have to tighten again.
Old Oct 28, 2003 | 12:10 PM
va97runner's Avatar
Originally posted by turboale
How the heck do you get to the oil filter. I changed mine for the first time wed and so the place that did it last time put it on really tight. I got the wrench, but how do you get a socket in there?? I don't even have any skid plates in right now and couldn't do it. Do you do it from the bottom or the top?
Thanks!
I do mine from the bottom. I don't even need to jack it up, now that I'm lifted. But in regards to getting it off, I don't need a wrench. I always use the FRAM Sure-Grip (or something like that) - the top of the filter is covered in a grippy material that doesn't get slick. Makes it 100 times easier.
Old Oct 28, 2003 | 12:48 PM
  #25
Mad Chemist's Avatar
Reaching in through the flap in the Driver's side wheel well is the only way to get a straight shot at the filter. Filters should only be on hand-tight anyways (I do turn it as absolutely as tight as I can by hand). If you've dipped the seal on the oil filter in oil, as you're supposed to, the seal will swell a bit and assure that you've gotten a good seal. Next time you change you're oil, no need for a wrench, just have to work it off with your hands.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
HRDC0R19
Jul 5, 2015 06:43 PM
