think my starter is going out
Old Dec 19, 2002 | 07:45 AM
david in germany's Avatar
Question think my starter is going out
last couple of months since toyota did my timing chain and clutch the truck has acted like the batterie was dead and would click when you turned the key then would eventualy kick the starter going. yesterday it was acting like this and thought it was the batterie again and went to jump it withmy celica (140 amp alternator and nothing. i checked the voltage before the jump and after both 12V Without the jumpers and tonight after trying my other optima it tried to turn over (fogot to mention lower 30's weather) so hooked up the jumpers again and finaly got it going. what do you all think? i have checked all the wireing and connections and each batterie has had a solid 12v charges at 14.5 whan running so the alternator is charging the batteries.
David
Old Dec 19, 2002 | 08:07 AM
Memphis4X4's Avatar
David in Germany: I had that happen last year. It is the contacts in the starter. Pull your original starter out and have it rebuilt for less than $100. In my '91, the resistance was building up so much in the starter wires that I also had to put in relay in-line so that the starter got enough "juice". Now, with both of these fixes, the truck starts perfectly again!!
David
Old Dec 19, 2002 | 10:18 PM
cheaper fix
David
site found parts ordered ( belt is tight) $100. is too much when i can do it myself for about $22.
check it out !
http://4crawler.cruiserpages.com/4x4...ks/index.shtml
David
Old Dec 20, 2002 | 12:49 PM
Memphis4X4's Avatar
Cool....I'm glad that you found a cheaper solution. Also, cool website.
BTW, the $100 I spent included the labor to remove, repair, and reinstall the starter. If you can save the $78 by doing it yourself....that's cool. I didn't have a long enough extension to remove one of the nuts holding the starter.
David
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
