Thing that hangs on the right of transfer case
Old Jan 22, 2007 | 08:21 PM
chadbobb's Avatar
Well i was cleaning off the mud from my 4Runner after going out and playing in a mud pit.
I noticed that on the passenger side of the transfer case is this little thing that hangs down. It doesn't hang down 100% straight and kinda curves.
First of all i don't really remmeber that being there, and number two if it was there i don't remember it being curved. I am kinda afraid that it was bent backward (toward the rear). Is it suppsed to hang straight down or curve backward. I can get some pics tomorrow if someone needs to see what im talking about or how bent it is.
Old Jan 22, 2007 | 08:24 PM
Elton's Avatar
pics may be helpful
Old Jan 22, 2007 | 09:50 PM
spaugh's Avatar
CIA tracking device. Have you been chatting online with your buddies in the middle east recently?
Just kiddin, there have been posts on here before about that thing, mine has one too. I've seen other 3rd gens and tacos that don't. I think its there to balance or keep the TCASE from vibrating.
Old Jan 23, 2007 | 06:09 AM
Bennito's Avatar
This question pops up from time to time, and the above is the generally assumed correct answer. Note I say generally assumed, not verified as fact.
I've got the hanger-on too.
Old Jan 23, 2007 | 11:30 AM
chadbobb's Avatar
so if i did bend it, it isn't so important something will break? Or does it bend from the factory kind of?
Old Jan 23, 2007 | 11:46 AM
spaugh's Avatar
bend it back or leave it or take it off, I don't think it really matters as long as you aren't noticing any vibrations while driving fast.
Old Jan 23, 2007 | 12:12 PM
MTL_4runner's Avatar
Need pics, no clue what part you're talking about here.
Old Jan 23, 2007 | 06:43 PM
chadbobb's Avatar
that is part of my problem... i don't know if its even bent to begin with... that is what im trying to find it... it it just tilts from the factory or if i hit something.
Pics later tonight
Old Jan 23, 2007 | 08:59 PM
spaugh's Avatar
here is mine, it is NOT bent
Old Jan 23, 2007 | 09:15 PM
YotaFun's Avatar
I still can't believe it is a weight,
I was under mine today and say it, it feels like rubber...
Also anyone make a beefier skid for are t-case...
that little thing is to dinky in my standards....
Old Jan 23, 2007 | 09:17 PM
Elton's Avatar
i says it a balancer of some sort
Old Jan 23, 2007 | 10:22 PM
fork's Avatar
it's a magnet, for attracting hot chicks!
Old Jan 24, 2007 | 05:14 AM
Gerdo's Avatar
Here is a skid, scroll down. http://www.budbuilt.com/new/ I'm thinking of making my own simple "slider skid" out of aluminim sheet. It won't take realy hard hits but it should deflect stuff. I have the weight on mine too.
Old Jan 24, 2007 | 05:20 AM
milowilli's Avatar
Its a vibration damper
Old Jan 24, 2007 | 05:23 AM
19RUNNER86's Avatar
i llike spaughs theory... cia tracking device
Old Jan 24, 2007 | 08:28 AM
Ringmaster's Avatar
Like he said.
I have removed the dampener on my rig, and noticed no difference in how much the trans gear shift wiggles/flops around at highway speed.
To me it's just another headbanger under the rig.
Old Jan 24, 2007 | 10:08 AM
YotaFun's Avatar
Thanks for the link
I am still debating makin my own just for there or gettin that entire plan
When i went to paragon a stick got caught between the front drive shaft and the t-case and made a noise that sorta sounded like the drive shaft had dropped out...
I don't want to hear that sound again...
Old Jan 24, 2007 | 03:49 PM
BruceTS's Avatar
It's a vibration dampener, most likely installed because the drivetrain created a frequency that the factory deemed excessive. I took mine off, figuring it wasn't needed since I changed my harmonics by adding a crawl box.
Old Jan 24, 2007 | 03:51 PM
Doug S's Avatar
That is called a Mass Dampener, as it's been described Milo and Ring-it sucks up the harmonic vibrations associated with things that move or spin fast. Basically it changes the sine wave so they are not noticiable and/or do not grow in intensity.
Doug
SMOD
Jul 23, 2015 10:29 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
