temperature control problem
Old Oct 26, 2009 | 07:57 AM
Dan Evans's Avatar
i have a '97 4runner with a heat issue. when i slide my heat control lever on the dash to cold it slides over and makes a subtle whomp noise. however, when i slide it back to hot there is no noise and no heat comes out. sometimes i can force the slider to the right and hear the noise and get heat but not always.
i know my next step is to take off the faceplate that covers the controls but i'm wondering what the soultion is? maybe a good squirt of WD-40 or is there a spring that needs to be replaced.
thanks.
Old Nov 1, 2009 | 06:45 PM
brian2sun's Avatar
Well, on my truck the cable from that lever goes through the firewall to a turning mechanism located in the middle and at the top of the firewall. Have some one move the lever as you look at it and you might be able to see the problem. I'm guessing yours is a V6 too?
Charecter1
Nov 6, 2023 10:08 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
voiddweller
Jul 15, 2015 03:56 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
