Tacoma Electric Fan Mod
Old Nov 1, 2005 | 04:42 PM
mt_goat's Avatar
Originally Posted by sandiego
I have the taurus fan and it isn't going into the shroud. The other fan to the attached link was from a volvo. This might be a better fan for the 3.4 application. I am hitting on one of the corners of the taurus fan. It doesn't matter how I turn the taurus fan I have some type of obstruction. The shroud over the fan won't sit flat. This is still going to happen. I just haven't seen a good how to write up yet. I will do some grinding and fitting this week. Did I mention I love air tools. I'll keep you guys updated, but it isn't an easy mod, atleast not as easy as I thought. Thanks for the links and info.
Can't you just cut off the offending corner, I don't see that you need any of the corners from the taurus shroud do you? The important thing is to somehow get a good seal between the two shrouds and they be secured together.
Old Nov 3, 2005 | 05:05 AM
sandiego's Avatar
There will be some cutting going on this weekend, at least that's the plan. See what doesn't fit and chop it off a little at a time. I agree with you Mr. Goat, a good seal between the shrouds and that it gets mounted is the important part. I will keep you guys informed.
Old Nov 3, 2005 | 05:16 AM
mt_goat's Avatar
I guess you may want to see how the Taurus shoud fits by itself before you cut it up.
Old Nov 6, 2005 | 10:56 PM
sandiego's Avatar
I have the shroud ready to go in the truck. I mounted the fan inside in the aluminum shroud I made. I have enough clearance for the Water pump. I have to trim some of the plastic on the fan to prevent hitting the radiator when the fan/shroud is installed. It's coming together and it is going to work. I haven't seen to much info on the Taurus fan on the 3.4. There are a few sites I did see thanks to you guys. I did very little cutting on the Taurus fan. Most of my cutting was on the aluminum shroud plate. I'll try to get some pics if anyone is interested?
Marc, how did you hook up the mechanical temp gauge? I can't find a port for the temp gauge. Can I drill a hole in the block and use super glue or JB weld
Old Nov 7, 2005 | 05:25 AM
  #25
mt_goat's Avatar
Pics please!
Are you really going to cut the fan? Surely you mean the shroud?
Old Nov 7, 2005 | 10:02 PM
  #26
sandiego's Avatar
Here are some pics of my home made shroud. You can see the lip I may have to cut. I had the fan mounted on the outside of the shroud, but it hit the water pump. I trimmed the shroud to stick the fan inside the shroud, now it looks like it will fit without water pump interference. I might get by without trimming the edges on the fan. You can see this in the pic of the fan side ways. It should work out, but taking a lot longer than I thought.
Attached Thumbnails Tacoma Electric Fan Mod-fan2-2-.jpg   Tacoma Electric Fan Mod-fan6-custom-.jpg   Tacoma Electric Fan Mod-fan8-custom-.jpg
Old Nov 14, 2005 | 09:41 PM
  #27
sandiego's Avatar
I will add some new pics by Tuesday, hopefully. Any questions or comments on the shroud so far?
T
Old Nov 15, 2005 | 05:55 AM
  #28
mt_goat's Avatar
I'm shocked by how big it is, is that the same size as your 3.4 radator? Are you going to use some kind of seal around the outside to draw the air through the radator?
Old Nov 22, 2005 | 12:51 PM
  #29
Poopshute's Avatar
Any of you guys heard of the Perma-cool set up? I just did it and was able to use the stock shroud. The install wasn't too difficult at all. I went with a fan and controller that a bunch of Taco owners have done. An 18" fan with a probe style controller (comes with the A/C relay and a adjustable temperature built in). I ended up spending $180 flat for the entire job.
Old Dec 26, 2005 | 03:39 AM
  #30
sarcher's Avatar
From: Hartville, OH (near Canton & Pro Football HOF)
Originally Posted by TacomaTRD
Belt sizes:
PS 102cm I think a 103 would also work
Alt 92.5cm I think anything from 91 to 92.5 would work
I cut down my fan bracket about 1" behind where the pullies mount using a cutoff saw. I had to remove one of the studs holding the fan bracket closest to the alt so the alt belt could clear. I plan on taking off the bracket and milling down where the nut seats and installing a bolt.
Not running a fan currently, it was around 25F last night and the temp stayed in the normal 50% position... Will probably do timing belt/water pump install elec fan and mod the old fan pulley bracket over the holidays...
I'll post some pics once I get a new reader for my camera...
I've got a 94 "Truck" and have been thinkin' of an electric fan mod too. (Mostly to see if it gains me any HP --- my little 22RE is wimpy, and I think this is 1 little "help")....how did this ultimately turn out for you?
Do you know the details of what you've got to do electrically (thermostat/thermoswitch) to control fan's operation?
Old Dec 26, 2005 | 07:20 AM
  #31
mt_goat's Avatar
I'm going to use what's in the link in post #17 of this thread.
coryc85
Sep 9, 2015 06:24 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
