Tacoma broken leaf spring
Old Feb 24, 2003 | 01:00 PM
robbieracer's Avatar
Question Tacoma broken leaf spring
I have a 97 Tacoma 4x4 V6 ext cab with a broken leaf spring, there are 3 normal springs and one overload spring. The bottom spring broke. I called the junkyard and they want $150 for the whole spring assembly. To have one spring made it's $140. I notice Downey/Performance Products have add-a-leafs for $45. could I remove the lower spring and install this. Or maybe buy two new springs, I see Old Man Emu has a set for $350, but it looks like they are 98' and newer. I primarily drive this on the street and don't want big tires, a small lift would be okay, preferable less than 1 1/2" Are there any other options out there??????
Old Feb 24, 2003 | 01:07 PM
keisur's Avatar
Re: Tacoma broken leaf spring
my only advice would be to do the same thing to both sides. kind of like breaks. otherwise it might ride funny.
Old Feb 25, 2003 | 06:31 AM
Bumpin' Yota's Avatar
So only 1 of the 3 leaves broke? How does that side sit now with only 2 leaves? If it's a possibility you could just take the other leaf out of the other side if necessary....dunno just brainstorming on that one.
Old Feb 25, 2003 | 07:02 AM
I don't think it would be too safe only having two working leaf springs... I'm thinking I may just buy an add-a-leaf to replace the lower springs and hope it doesn't lift the rear end too much...
88sasturbotoy
Jan 30, 2026 01:57 PM
nvdesertrunner
May 11, 2020 08:18 PM
shisha1999
Sep 21, 2015 08:22 PM
priest16
15
Aug 6, 2015 07:43 AM
Nickdigg
Jul 7, 2015 06:04 AM
