Taco Time
Old Jul 17, 2012 | 09:09 AM
SeaWulf's Avatar
Taco Time
I just bought a new-to-me 1996 Tacoma. It's a 4x4 with the 3.4l V6 and 5 speed. The only option it has is AC, it doesn't even have a trip odo or factory tach.
It's got some kind of undetermined 3" lift and it's on 33" KM2s; the rear springs are definitely newer and I don't think it's an AAL setup. It doesn't have spacers up front either.
This upper ball joint obviously needs to be replaced. This is an aftermarket adjustable setup since it's threaded, right? It's not marked that I can tell.
Now to my questions:
Is the speedometer mechanical or electric? I need to figure that out and correct it for the tires.
Is there wiring in place to add an aftermarket tachometer? I searched and came up with conflicting info
Is there a factory chime that sounds a couple times after you shut the motor off? I didn't find anything in my search, so it might have some kind of alarm system installed.
Is there a good way to remove odors from the interior? I bought it from a farmer and it smells like Jalepenos inside
I need to find some mudflaps for the front and fix the silly rear ones. I also plan on adding a tachometer and a scangauge.
Old Jul 17, 2012 | 09:30 AM
dropzone's Avatar
Fossilized
Nice that it has manual hubs. Some one must have converted them. I was under the impression manual hubs only came with the 3rz 2.7 4 cyl..
Old Jul 17, 2012 | 09:31 AM
MaK92-4RnR's Avatar
manual hubs came on the early models pretty frequently. even 3.4 v6 5 speeds.
Old Jul 17, 2012 | 09:41 AM
SeaWulf's Avatar
I figured out what the beeping noise is; the cheap Sony deck beeps multiple times when the key is turned off. I assume it's to remind you to take the face plate out or something
Old Jul 17, 2012 | 09:56 AM
MaK92-4RnR's Avatar
^^^ lol yes.... they all do that.
Old Jul 17, 2012 | 10:51 AM
jslone's Avatar
Great condition, gotta love Colorado. How many miles?
Old Jul 17, 2012 | 03:10 PM
SeaWulf's Avatar
183k miles.
Here's what I know so far:
The front lift is a Downey setup and the rear springs are Alcans.
It has a diff drop that I'm going to take off since I have manual hubs.
I'm probably gonna sell the 33" KM2s and get some 31s because it's still on stock gears.
The girl I bought it from forgot her Plan B pill tucked in the wire under the seat. It might be time for plan C :laughing:
Old Jul 17, 2012 | 03:32 PM
dropzone's Avatar
Fossilized
Cool. When I bought my 97 new, I went with the 4 cylinder, none of 3.4's on the lot had manual hubs..
Old Jul 17, 2012 | 04:06 PM
willmasterflex's Avatar
clean looking taco!
im assuming those km2's are 33x10.5x15? if you're interested in selling them, i may be interested in buying them seeing as you're in colorado as well.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
