T4R Rear Drum Problem
Old Nov 28, 2006 | 06:57 AM
automated11's Avatar
Unhappy T4R Rear Drum Problem
I have read through the other posts about rear brakes and havent really found an answer so here goes my problem.
I was getting pulsing vibration from my brakes. I originally thought it was the front rotors. WRONG, with new brembos and pads it was still doing the same thing. So then i went to the rear. Ebrake linkages seem fine. BUT the drum on the drivers side has hot spots where you can tell the metal is a different color in different places from being very hot. No hot spots on the passenger side. So i replaced the drums thinking that the person before me towed and possibly overheated them. Now about 3-4weeks later the same thing is starting to happen. The vibration totally went away when i replaced the rear drums and the same vibration is back. Does anyone have any experience with this or any insight for anything in particular to fix.
Thanks, Jason
Old Nov 28, 2006 | 08:54 AM
BTW this is a 1997 3rd Gen 4runner
Old Nov 28, 2006 | 10:34 AM
rimpainter.com's Avatar
2 questions:
1. Are the shoes worn evenly?
2. Are the rear brakes adjusted properly? If not, or if you don't know, respond here and I will help you out.
Old Nov 28, 2006 | 11:37 AM
Yes, the shoes are worn evenly, and i adjusted the brakes by using reverse and pulling the ebrake lever a few times.
Old Nov 28, 2006 | 11:47 AM
bruizer's Avatar
Vibe
Wheel bearings caused a vibration in my rear end.....replaced them...Name:  145859_avatar.jpg
Size:  6.8 KB....no more problemos.
Old Dec 19, 2006 | 07:24 AM
MotaPsycho's Avatar
wheel bearing
Hi,
I was wondering if you had change the wheel bearing and cured the problem? I believe this is happening to me as well.. we change the rear drum.. but its still vibrating... do you know the part number for the wheel bearing?
Thanks!!
Old Dec 19, 2006 | 09:01 AM
I did not change the wheel bearings as of yet. It doesnt appear to be my problem. Im going to be changing out the shocks and struts first because they have 120,000 on them anyway and my ride seems really good on extremely smooth concrete anything else it sucks
Old Dec 21, 2006 | 09:58 PM
tom_mag's Avatar
How much drag is there when you turn the rear wheel manually? If it is adjusted properly you should be able to give it a good spin and it will stop within one revolution. If it stops right away then the brakes are set to tight, if it spins more than a revolution then it is too loose and the brakes will be grabby.
Old Dec 22, 2006 | 06:08 AM
Ill check that this weekend. But if they are too tight how do you get them to stay in check? They auto adjust when you use the ebrake right?
Old Dec 22, 2006 | 10:23 AM
I personally do not like the e-brake adjustment method because it doesn't work as well as adjusting the star wheel with a flathead. Regardless, you still have a vibration problem. Wheel bearings going bad on these is extremely rare. At least that's what all the Toyota guys tell me. I had a parts guy, service manager, and a shop foreman tell me that. I tend to believe them considering I could have been potential business for them...
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
icentropy
Jul 11, 2015 07:21 AM
icentropy
Jul 9, 2015 02:12 PM
