T-Stat Replacement... hard?
Old Sep 15, 2004 | 04:10 PM
joshik's Avatar
hi, ive searched for posts on replacing tstats. seems like lotsa ppl have probs with overheating and their tstats.
i got my oil changed today and the mech recommended that i change the tstat. $39 for part and $75 for labor. i was all forget that. imma do it myself!
lately, my car has been overheating... but only when im at a standstill or in heavy traffic in LA. If im not moving and no air is passing thru my rad, it starts to overheat. but once im out of traffic, and start moving it slowly goes down. I have to turn off my car while i wait in the drive thru at MC D's
What else could be the culprit? would following the mech's advice and changing the tstat fix the problem?
how hard is it to change the tstat? i'll look more into my haynes manual when i get home tonight.
thanks!
<josh><
Old Sep 15, 2004 | 04:12 PM
superjoe83's Avatar
it probably not the thermostat if it comes down after you get air through the radiator, you fan clutch probably is not working any more, i would try replacing that first
Old Sep 15, 2004 | 04:14 PM
joshik's Avatar
ah icic. cool deal. ill check that out. so the fans not cooling the rad.
Old Sep 15, 2004 | 04:19 PM
superjoe83's Avatar
heres a way to check it, when the truck is cold, like in the morning, try to spin the fan, it should pretty much stop when you let go of it, if not, then its probably lost its viscous fluid and is just freewheeling now
Old Sep 15, 2004 | 08:49 PM
jimbo74's Avatar
$39 for the part! holy crap?! is it made out of 24k gold wit ha lifetime warranty? i bought the stock replacement tstat from the toyota dealership for my truck last week and with the gasket it was like $11
Old Jul 20, 2010 | 08:02 AM
CLin9383's Avatar
I am having this problem. i just replaced the radiator with a KOYO and still the same thing. also if i blast the heater on full, the gauge drops back to normal. i burped the rad the best i could but this was happening even before i changed the radiator. fan seems ok so i guess i should replace the tstat? thanks
update:
https://www.yotatech.com/~corey/tech...t/haveblue.htm
Old Jul 20, 2010 | 10:39 AM
J2F42C's Avatar
Fan Clutch Inspection....
this link should help: page 1
https://www.yotatech.com/forums/f2/a...cooler-205767/
Change out the T-stat regardless for cheap insurance.
Old Jul 20, 2010 | 02:12 PM
99yota4's Avatar
It's an easy process. I did it and I'm just learning about my runner. The T-stat for the 3.4 engine is on the lower rad hose. Make sure you do it while it's cooled down obviously, and you have to drain the radiator fluid, so it'd be a good time to do a flush. Take the 3 nuts off of the pipe housing and it comes right off. the t-stat is sitting there and will most likely just fall out. Just replace it and you're basically done. Refill your radiator with proper coolant and burp the system.
Old Jul 20, 2010 | 02:19 PM
Elton's Avatar
ya its super easy to change the t stat
Longbed 90
Mar 11, 2019 12:38 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
charlie_fong
Sep 27, 2015 10:06 PM
anndel
Sep 10, 2015 08:50 AM
