synthetic motor oil ‘true or false’
Old Mar 24, 2006 | 09:02 AM
BajaRunner's Avatar
Um... gravity will always pull oil down to the drainpan no matter what... I dont think it matters if its syn or not. Maybe the dyno stuff is thicker in some senses and the goop that accumulates over time may be thought to be a better lube?
I have developed a small oil leak coming from what looks to be a front seal from switching to Mobil 1. I did an Amsoil oil flush clean, and I think it washed out all the goop/debris/buildup from dyno oil and now the new synthetic can seep out slowly from an old seal.
Old Mar 24, 2006 | 10:29 AM
MTL_4runner's Avatar
Yep.....both will leave a film which should be sufficient for startup. The bigger factor is to make sure you have an oil filter with an anti drainback valve (with the OEM Toyota ones do have). This makes sure oil goes where it needs to more quickly after sitting and hopefully causes less wear and no "bucket of bolts" sounds at startup.
Old Mar 24, 2006 | 12:03 PM
Beartracker's Avatar
Been running Mobile 1 5w-30 for a while now in my 01 2.7 Tacoma , change it every 10,000 miles. No problems yet and I do some hard mountain driving. When I start it up it's as quiet as baby sleeping and idles like a kitty purring,Lol.
Old Mar 24, 2006 | 01:36 PM
4RUNN!N's Avatar
Since I purchased my 4R about 9K miles ago, it was sold to me with a fresh oil change but wasn't sure what type of oil was put into the engine, but I'm thinking about changing it to M1 5W-30 Syn just like I did in my previous car, but the weird thing is that even after 9K daily driving miles and maybe 2 times a month going on a road trip and some off-road advetures, the oil is still not dingy and black, instead its a little murky but still the brownish transparent color. Would it be a waste to change the oil now?
Old Mar 24, 2006 | 03:04 PM
  #25
WATRD's Avatar
The color, smell, feel and taste of oil have nothing to do with whether it is suitable for continued use. Either change it on a schedule or have it analyzed, but don't fool yourself into thinking you can distinguish good oil from bad simply by looking at it. It's not mayonaise.
Old Mar 24, 2006 | 03:48 PM
  #26
spindleshanks's Avatar
Originally Posted by WATRD
Huh?
Amsoil is fully synthetic, unless you are specifically buying one of their "Blends".
http://www.amsoil.com/storefront/atm.aspx
Nope, Bruce has got it correct. All synthetic oils come from petroleum products. The desirable qualities of conventional oil are maximized through additives and engineering to make a synthetic.
Old Mar 24, 2006 | 04:01 PM
  #27
WATRD's Avatar
Prove it.
Everything I see says they are made from purely synthetic base stocks.
AMSOIL Synthetic Lubricants are fuel efficient, extended life lubricants manufactured from select synthetic base stocks and special purpose additives.
In 1972, AMSOIL introduced the first American Petroleum Institute rated 100% synthetic motor oil for automotive applications.
...and many more...
Old Mar 24, 2006 | 04:20 PM
  #28
ttus's Avatar
Mobil 1
Old Mar 24, 2006 | 04:30 PM
  #29
rugerm44's Avatar
The thing that tears me up is how it went up in price.Its man made right, so why did it sky rocket when dino oil and gas went up.Go figure
Old Mar 24, 2006 | 04:42 PM
  #30
ttus's Avatar
Mobil 1
Been using Mobil1 in all my cars and truck.
04 CV
04 Tacoma
96 TC
97 Chev. 4x4 duallie 454
Old Mar 28, 2006 | 08:17 AM
  #31
blzorro's Avatar
Check this out--- http://synlube.com/prod01.htm You dont have to change your oil ever again this stuff was used on our mission to mars!
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
