Synchronizers... t-case
Old May 10, 2003 | 09:04 PM
juicyfruity's Avatar
I have a 2000 Tacoma with the conventionnal 4wd selector(non-TRD). When the truck was new, I had no problems shifting from 2Hi to 4High up to 50 MPH. And then I got the charger and the fuel mods... I got addicted with flooring the truck at stop lights, and at low speeds to smoke thoses rice burners yeah! I had much less axle wrap this way and in the end, my tires were in better shape... I have major traction issues in 2wd.
Now, It grinds when I shift from 2hi to 4hi at more than 30 mph...
Anything I can do to help this cause? other than taking it easy?
Anyone replaced their synchronizers in their t-case?
Old May 11, 2003 | 07:28 PM
tomus1000's Avatar
<bump>
Are you saying that your were launching the truck, on dry pavement, in 4WD? That certainly can't be good for the truck. I don't know the answer to your problem, but someone here might.
Old May 11, 2003 | 07:45 PM
Shane's Avatar
Re: Synchronizers... t-case
Um, unless theres something I don't know about the newer transfers, there are none. You might want to take a close look at your front driveline, you probably broke something. Also might want to put your right foot on a diet...
Old May 12, 2003 | 12:13 PM
Yes! But only maybe 10 times. Toyota drivetrains are STRONG!!! But now I don't do it anymore.
I'm pretty sure it's a synchronizer in my t-case. I've seen the diagrams in the toyota repair manual.
Everything sounds good and solid. It's just that I have to go slower before engaging in 4wd. The cause of this problem is not launching in 4wd, it's because I would always play between 2 and 4 high. Same thing in a tranny as slaming the gears, never double clutching, shifting to redline...all the time. After a while, you get a crunch when you shift, especially between 1 & 2, and 2 & 3. That means your synchros are worn.
Old May 12, 2003 | 12:22 PM
rimpainter.com's Avatar
Let me get this straight. You drive a supercharged Tacoma, have a lead foot, like to smoke ricers, launched no less than 10 times in 4WD (in the past)...
and now you have transfer case problems.
A used transfer case would be your most econmical fix. By the time you tear apart your existing case, labor alone will set you back a pretty penny. I have seen these x-fer cases on ebay. You could check there.
ClintonP929
3.4 Swaps
64
Jun 13, 2017 01:46 PM
Rowdydudeman
Nov 26, 2015 02:17 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
priest16
15
Aug 6, 2015 07:43 AM
