Sweet rigs :)
Old Oct 10, 2007 | 07:35 PM
  #121
Elton's Avatar
few more of mine with my bike
Old Oct 12, 2007 | 07:53 AM
  #122
Speedy's Avatar
Project SportRunner
I used to be into 4wheeling and had a couple of 4x4 Tacos (charter TTORA TN Chapter President) but with this 4Runner it's more of how clean can I keep it.
Stock on 9/06
Modified 10/07
Old Oct 12, 2007 | 10:49 AM
  #123
Fo_SheeZy's Avatar
Looks really nice, I like those rims!
Old Oct 12, 2007 | 04:51 PM
  #124
vinnymac's Avatar
The Supermoto bikes rule, Elton. I am an avid motocrosser and REALLY want a KTM 525SM.
Old Oct 12, 2007 | 06:27 PM
  #125
crolison's Avatar
New bumper made and installed.
Old Oct 13, 2007 | 04:55 PM
  #126
Atomic's Avatar
^ looks great! You'll have an awesome approach angle!!
Old Oct 18, 2007 | 08:29 AM
  #127
jschmitt's Avatar
Here's a few pics I have.
Old Oct 18, 2007 | 08:51 AM
  #128
4runner46's Avatar
Old Oct 19, 2007 | 10:59 AM
  #129
Kiroshu's Avatar
It's mine....i dream of what i could be
This is my 95 Toyota 4runner with a few things but i want alot more for it like lifting and fixing a couple things.....any ideas?
and how do you put pics on here it was like either too big or its not workin
Old Oct 19, 2007 | 11:08 AM
  #130
jason191918's Avatar
Originally Posted by SteveO
Here's some Eye Candy for ya wheelers:
that is f'in awesome
Old Oct 19, 2007 | 10:34 PM
  #131
Djlarroc's Avatar
Damn Dude!!!!
Old Oct 20, 2007 | 08:07 AM
  #132
SteveO's Avatar
heh,
It does pretty good.
Being that I ripped out the ABS (speed sensors), I've been without a speedometer for some time. But, I believe I have a very easy solution for those who want to SAS their rigs and also remove all of their ABS signals, as I have done.
I just put in the Speed Sensor today, and confirmed that it physically works, now I just need to hook up the wires.
As for the pictures, those were taken with the off-road tires, the 37" MTR meats. For the highway, commuting, and daily driving, I have the kid tires, 35" BFG/AT tires. Its really amazing what the 4Runner looks like when the tires are switched. I'll have to get some side by side shots for comparison.
Anyhow, thanks for the kind remarks.
Old Oct 20, 2007 | 08:15 AM
  #133
neliconcept's Avatar
heh,
when i took out my front abs, my speedo worked for a while and now it doesnt, which sensor it is Steve?
Old Oct 20, 2007 | 02:35 PM
  #134
SteveO's Avatar
It depends on your model.
I picked up a speedo sensor from a '98 Tacoma V6, Auto 4x4 with an electronic sensor on the speedo gear. In my manual it shows a worm gear that goes around the output shaft of the transfer case; in the tailhouseing. So, today I put this sensor in there, removed the electronic part and had my wife move the 4Runner to see if it would move. It did. So, now I know the worm gear is there to turn the speed sensor gear. Now, I just need to hook up the electronics.
If you have a Limited, there are actually two speed sensors; Sensor 1 is the ABS, sensor two is on the transmission. The second is used to control the Automatic transmission, in the event the 1st speed sensor, the ABS, fails. I though about hooking into these transmission sensor, but never really got around to it. Maybe I'll test it out anyway, just to see if it works.
does that help you?
Old Oct 20, 2007 | 02:57 PM
  #135
crolison's Avatar
Ahhh isn't it nice not to have abs from the factory
Old Oct 20, 2007 | 03:01 PM
  #136
does that help you?
well I got a PO500 code right now. basically it says speed sensor A, I have my front ABS sensors hanging beside the spindle zip tied due to manual hubs and the spindles do not have ports for the abs sensors. Which may make me use my old spindles and have man hub wheel bearings pressed into them and reuse the abs and get my VSC trac back
mine is an 01
worst freakin 4runner for electronics till the 4th gens.
Old Oct 20, 2007 | 05:52 PM
  #137
BigSquatch's Avatar
pretty much stock
Old Oct 20, 2007 | 06:39 PM
  #138
SteveO's Avatar
......I have my front ABS sensors hanging beside the spindle zip tied due to manual hubs and the spindles do not have ports for the abs sensors.
Well, there's your problem. The ABS sensors ARE the speed sensors. When you pull these, you will get the P0500 code. If you still have the rear ABS sensors, you may be able to patch the front ABS lines into the rear lines, using the rear signals as the front signals. In my case, I have the Full Floater setup, so I don't have any rear ABS sensors either. No rear front or rear ABS sensors = no speed signals at all.
I just did some research on the '98 Taco "3 wire" speed sensor, and it is looking pretty good. Since my Auto tranny has a second speed sensor, the tranny still works correctly.
Old Oct 20, 2007 | 07:31 PM
  #139
xcmountain80's Avatar
Hmmm this is why I retained my stock spindles in order to keep abs I had the outer hub ring installed backwards so it wouldn't interfere with the abs. So ABS work well and still have not tested my front locker nor the full capacity of my rear.
Aaron
Old Oct 21, 2007 | 11:01 AM
  #140
ADH8796's Avatar
