Suspension. CHECK! Tires. CHECK! now what?
Old Nov 12, 2008 | 10:43 AM
sschaefer3's Avatar
Originally Posted by wmflyfisher
Looks nice! I hear a lot about the SS kits but I do not like how they sit higher in the back. Does this last very long or what?? I would like mine to sit level as possible or maybe a 1/4" higher in the back.
System 7.2 sits dead nuts level. That is why we made it.
Old Nov 12, 2008 | 08:32 PM
SWPERIC's Avatar
STEVE!!! (this is eric from chicago) THANKS A MILLION FOR MAKING AN AWESOME PRODUCT!!! and with service to match.
Old Nov 12, 2008 | 08:50 PM
SWPERIC's Avatar
o man... im getting that itch again... well it actually never stops. and its not crabs. its the itch to mod this gorgeous 4runner of mine. the spray paint on my BudBuilt skid and belly plates is drying as i type. I am ordering sliders in a week or two and that has me thinkin. am i going to want a body lift after i weld these on?
i am pretty sure i understand all the benefits (more space in wheel wells for stuffing, more room to work under truck, etc.) but i have not read enough CONSTRUCTIVE criticism on them.
i would probably only do 1 inch or MAYBE 1.5 because i read that these involve few complications.
there are profile pics in the opening post. I would just like to know some of your opinions. to body lift or not to body lift?
thanks!
Old Nov 13, 2008 | 04:09 AM
sschaefer3's Avatar
I would not do a body lift unless you "have to". The only reasons you would have to is to fit actual 35" tires or a Marlin Crawler, dual case setup.
If you don't plan on re-gearing, which you will have to do with 35's leave it on the frame, all the little stuff to fix is a very long and expensive list.
Sliders, Skids and Lockers all make sense to me.
Old Nov 13, 2008 | 07:50 AM
  #25
TC4RNR's Avatar
it depends on how much crap you take when you put the bigger tires and lift in use (a.k.a. go off-roading). i carry about 300lbs of extra weight when i go out, with the SS1.2, the rear is dead level. i can bet on if yours is level empty, it will sag when load up.
my 0.02
Old Nov 13, 2008 | 08:00 AM
  #26
TC4RNR's Avatar
i would find a shop to cut a 3" or 4" hole on the bud skid before you put it on, i did it and it makes a big difference when changing the oil. the shop i know pretty well won't do my unless i had a hole for the oil drain because the shop owner didn't want the mechanic got hurt while wrestling that 50lb beast. that's the down side of having something beefy as a budskid. he.he..
and, if you want sliders, steve carries Stubb's, i just had the newly designed HD-SKO, i really really like it, specially the way the kickout was layed out.
it comes with all the 4 legs cut to length for your model/year, scab plates also welded, all the metal surface buffered to a chrome shine. all left for you is to paint it then weld on to the frame. for me, it's the best i've seen so far.
Yotadawgjr
10
Aug 23, 2015 10:51 AM
B1gR3d
Aug 1, 2015 10:10 PM
coffey50
Jul 28, 2015 10:55 AM
andrewtexas123
Jul 23, 2015 11:22 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
