supercharger and trd 7th injector questions
Old Sep 1, 2007 | 01:25 PM
Texas_Ace's Avatar
True that is a problem but for me the extra $1000+ is worth a little time. That is the VB job on the tranny or the 7th injecter kit or the tourqe converter. but if you have the $$ go for it!
Old Sep 1, 2007 | 01:33 PM
MARSHALLMAY's Avatar
the bigger question for me is, is 150k miles too many to add a s/c? I'm thinking it is, but when I add it, I will be prepared for an engine or tranny overhaul. Which would be a bittersweet thing to do.
Old Sep 1, 2007 | 01:35 PM
Texas_Ace's Avatar
Depends on how well the engine has been taken care of. Have you done a compression test?
I am about to do mine at 125K, and 150K should be fine but doing a compression test can't hurt and will give you a good idea.
Old Sep 1, 2007 | 01:39 PM
I'm not as worried about the compression as I am the wrist pins and crank bearings. But yeah I guess a compression test would be a good tell tale on the rings. 2 good things I do have, golden oil at 3000 miles and no oil usage.
Old Sep 1, 2007 | 01:40 PM
  #25
Texas_Ace's Avatar
Yeah same here, doesn't use a drop of oil and the oils looks clean at change time.
Old Sep 1, 2007 | 02:17 PM
  #26
sorry about hijacking the thread, but I would think the most secret trick, besides the installation manual, is being well organized while doing the install. A nice workbench or table to lay out everything. A method of labeling bolts removed and where they go would also be handy. Last year I swapped an engine for my buddys' 92 chevy. When I was done I ended up with an extra bolt. To this day I still don't know what it went to and his truck is running fine. Kinda scary if you think about it.
Old Sep 1, 2007 | 03:14 PM
  #27
Texas_Ace's Avatar
Extra nuts and bolts are a sgin of a job well done! The more the better the job!
Old Sep 1, 2007 | 05:59 PM
  #28
dijlop's Avatar
lmao. then dude, my stereo install in my last truck was FLAWLESS!!! i had 6 screw, 1 tab, and 2 random metal parts, not to mention the stock unit and the stock speakers. i must have some serious skill.
Old Sep 1, 2007 | 06:04 PM
  #29
Texas_Ace's Avatar
LOL, i have you SOOO beat! I have a BOX of stuff extra in the garage of stuff from MY stereo install!
Now we might want toget back on topic...lol
Jun 1, 2021 01:51 PM
Toyvana
Jul 29, 2015 10:47 PM
anniesball
Jul 29, 2015 11:46 AM
Cplmike
Jul 8, 2015 08:47 PM
timmJ
Jul 7, 2015 02:01 PM
