Old Mar 30, 2016, 03:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Tire Repair and Maintenance
Print Wikipost
Suggestions for best lift to clear 33" tires on a 2000 tacoma
Old Dec 30, 2007 | 06:16 PM
BenBean's Avatar
I want to clear 33" tires, and not break the bank. I also do not want to worry about too much modification to the drivetrain. This is my daily driver and I do not want any additional wear.
I have heard that a 2.5" lift is the maximum to not interfere with the drivetrain. Is a 1'' body lift a good idea to get the added lift? Does the body lift require much work if it is only 1"? Would 3.5" clear 33 x 11.5 tires?
I have looked at OME, Revtech, and toytech. I would like to hear what others have done that works. Thanks.
Old Dec 30, 2007 | 06:32 PM
Dare44's Avatar
this has been covered many times in these forums, if u search it there are alot of threads on this, welcome to yotatech. I had a 4in trailmaster bracket lift on my older truck and it always worked as i wanted and never let me down. I used it as my daily driver for a year and had no problems.
Old Dec 30, 2007 | 06:58 PM
crolison's Avatar
do it right the first time, no spacers, no body lift. I would do a slight suspension lift and trim the fenders.
Old Dec 30, 2007 | 07:46 PM
d0ubledown's Avatar
3" body lift will clear 35's easily...and its cheap
Old Dec 30, 2007 | 08:18 PM
crolison's Avatar
Cheap and easy dont always equal good, that kind of thinking will probabley get you VD.
Old Dec 30, 2007 | 08:24 PM
crolison's Avatar
If not doing a winch or bumper, ome should be fine.
Old Dec 31, 2007 | 06:25 AM
FullXTR's Avatar
I say go with 2-3" body lift. It's cheap and won't break the bank, which you said you want, and it requires zero modification to drivetrain, which you said you want.
Old Dec 31, 2007 | 06:39 AM
Belize Off Road Team's Avatar
you can fit 33x12 tires with NO MODs and little rubbing from 1990 + until current on all 4Runner's and Tacoma's and T100's/Tundra's.
Old Dec 31, 2007 | 06:40 AM
Cuthroat72's Avatar
R u running 15 or 16 inch rims bro? 2.5 inches clears a 285/75/16 without rubbing on my 4runner. I think that is the equivalent of a 33x11.50. Knowing you, you won't be running any serious trails with a daily driver, but 2.5 inches should clear it no problem. plus, you'd have more ground clearance but afford a lower center of gravity (COG) than with the body lift.
Old Dec 31, 2007 | 07:18 AM
jjrgr21's Avatar
think about the tundra lift, i love mine. search the forum for info on it.
i can clear 255's with the tundra lift.
Old Dec 31, 2007 | 12:25 PM
4rx's Avatar
4rx
lol its not that cheap. I did little trimming in the front even with stock 16x7 wheels and some wheel adapters. then it's good to go
Old Dec 31, 2007 | 12:41 PM
b.miller123's Avatar
why do you want the 33inch tires?
You want bigger tires with no "additional wear" and no "driveline modifications"? good luck
I am suprised that no one has asked you about regearing yet, and bigger tires and wheel will always result in some form of increased wear on the vehicle
I want a truck with 300hp that gets 30mpg with 35 inch tires
Sorry to come off as a jerk, but do a search and you will find all of these answers in triplicate, what I would do: just put the tires on there and if they rub, then put a body lift or spacer lift or just trim where you need to, that's the cheapest, so not really the best
edit: Oh yeah, welcome to yotatech! search is your friend
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
Cplmike
Jul 8, 2015 08:47 PM
