Stuck idler/tension pulley
Old Jun 26, 2020 | 06:38 AM
92mn4runner's Avatar
1998 4runner v6
Any tips on loosing the AC tensioner pulley?
​​​​​​I've lossen the bolt I circled in green and the bolt I circled in orange just unscrew out without moving the pulley.
Old Jun 26, 2020 | 11:36 AM
irab88's Avatar
Have you tried PB-Blaster and a BFH?
Old Jun 26, 2020 | 11:55 AM
​​​​​​I've tried PB blaster but the space is to small to swing an BFH.
Old Jun 27, 2020 | 06:38 AM
Marc's Avatar
Have you tried removing the Bolt that is part of the Nut circled in green?
Old Jun 27, 2020 | 10:29 AM
I've tried and no, the bolt does not move. It's stuck in place.
Old Jun 27, 2020 | 12:07 PM
Marc's Avatar
That doesn't make sense.
If the nut is loose or off there should be nothing holding the bolt.
Have you tried to take the nut off and remove the pulley?
Old Jun 27, 2020 | 12:51 PM
the nut does come off but the pulley won't.
Old Jun 27, 2020 | 08:33 PM
fierohink's Avatar
Don’t you have to loosen #81085 as well to pivot the bracket and free the pulley?
Old Jun 28, 2020 | 03:11 AM
Not that I know of. I took that out when I had to remove the ad bracket.
Jf28142011
Feb 15, 2021 07:34 PM
GorgeRunner
Jul 24, 2009 12:35 PM
Tigerstripe40
Oct 23, 2006 08:00 PM
