Stuck Hubs ???
Old Feb 1, 2005 | 07:05 AM
88w/300K!!!'s Avatar
Stuck Hubs ???
I had the original auto locking hubs replaced with Warns on my '88 4Runner about a year ago. I had manual locking Warn hubs installed because they were supposedly more reliable. Well, now I go to use the Warns, and the hubs won't lock into 4x4. I can turn the dial on the hub, shift into 4x4, but the front wheels aren't pulling. I figure it's because I haven't used them but one or twice since they were installed and they aren't greased up very well. Does anyone have any advice for getting these things freed up? I'd rather not take it in for servicing...again.
Thanks, Craig, in Charlotte, NC
Old Feb 1, 2005 | 10:46 AM
Dryheat's Avatar
With one of the front tires jacked up off the ground and the 4wd off you should be able to engage the hub and rotate the cv back and forth to see if it has engage the hub. Sometimes it take a bit of shifting around before it seats. If it is engaged the shaft will rotate with the tire. If it isn't engaging remove the dial cover of the hub and look to see that the lock mechanism is moving. If I recall, it uses springs to engage the axle. You could remove the whole hub easily and check it.
Could it be that the diff isn't engaging the side shafts?
Good luck
Paul
Old Feb 1, 2005 | 11:12 AM
Paul,
Thanks for your reply. I think I found the problem. I had the right front CV axle replaced recently as well. After poking around under there, I saw that the axle isn't inserted all the way into the backside of the hub/wheel assembly. Something's screwed up there, no way it could work right. It's going back to the shop that did the work first thing in the morning. It's going to be their problem now.
Craig
Old Feb 1, 2005 | 05:16 PM
kyle_22r's Avatar
if you can, look into finding a set of AISIN hubs from a '86-95 truck or 4runner. they're much better than the warns on a toyota, since they're stronger(they use cone washers) and don't stick out as far as warns.
Old Feb 2, 2005 | 06:53 AM
Got it fixed. For anyone interested, a snap ring broke that holds the CV axle fully inserted into the hub. They put the axle in place and replaced the snap ring. Easy fix, and free too.
ladybugRC
458
Aug 21, 2020 10:41 AM
G-off
Dec 29, 2015 12:44 PM
AaronM
12
Nov 4, 2015 04:06 PM
stanz
Oct 30, 2015 10:33 AM
Toys4parts
Sep 26, 2015 01:56 PM
