Stock 4.88's and 33's
Old Feb 11, 2004 | 09:07 PM
my95toy's Avatar
i just found out that G144/ on my door panel means i got stock 4.8 gears. has anyone ran 33's with these?
Old Feb 11, 2004 | 09:09 PM
kyle_22r's Avatar
should be perfect for 4.88s.
Old Feb 11, 2004 | 09:12 PM
my95toy's Avatar
well the chart said they're 4.875. Is that a big difference gear wise from 4.88's? i wouldn't think so but i'm no mechanic
Old Feb 11, 2004 | 09:27 PM
Yoter's Avatar
Guest
Re: Stock 4.88's and 33's
So what does G294 mean?
Old Feb 12, 2004 | 06:36 AM
Brendan's Avatar
that is a 4.88 ratio. using only 2 digits on the right side of the decimal, the 5 makes the 7 round up to an 8 resulting in 4.88.
Old Feb 12, 2004 | 07:32 AM
beachtaco's Avatar
Re: Re: Stock 4.88's and 33's
from the 4x4 wire board - drivetrain specs
G = 8" diff
29 = 4.10 gears
4 = 4-pinion diff
Old Feb 12, 2004 | 07:49 AM
86toyota's Avatar
so if i read this right from the chart there might be 7.64's out there on a toyota.Why?
Old Feb 12, 2004 | 10:45 AM
kyle_22r's Avatar
most likely on a heavy truck or something. no way you're going to be able to make a 7.xx gear run on an 8" diff. maybe something like a dyna or other big truck like that could have them available
Old Feb 12, 2004 | 11:02 AM
mt_goat's Avatar
Do you have an auto or 5 speed? 5.29 works much better with 33's if you have the auto tranny. The OD gear on the auto is higher than 5th gear on the 5 speed.
Old Feb 12, 2004 | 11:08 AM
Fink's Avatar
I'm actually not even sure what kind of gears I have but I figured that since I had 31's on the truck when I got it that I have 4.88's on there...I'll check the stuff on my door panel when I get home to be sure.
Thanks,
Fink
Old Feb 12, 2004 | 11:25 AM
Ducky's Avatar
Aparently my axle code isnt on the list... unless im reading it wrong.
My Axle code is A03A
The dealer tells me they are 4.10's.
Old Feb 12, 2004 | 11:29 AM
mt_goat's Avatar
Fink, my truck came with the factory 31 inch tire package too and 4.88 gears. 31's with the 4.88 are about the same as 33's with 5.29, both however are geared too high IMHO.
The best set-up I have run was 33's with 5.71 gears with the auto tranny. With that set-up the 3.0 could pull the OD gear quite nicely in the 65-85 mph range. The only problem was the 5.71 gears didn't hold up more that about 40K miles for me. So I'm running 5.29's now.
Old Feb 12, 2004 | 12:17 PM
Yoter's Avatar
Guest
Currently have 35s & an auto trans. Jumping it up to 5.29s from the 4.10s. Should be a lot quicker shouldn't it?
Old Feb 12, 2004 | 12:30 PM
fooddude's Avatar
dang blue you have 4.10s with 35's how well does your rig go.
Old Feb 12, 2004 | 12:36 PM
Yoter's Avatar
Guest
Chitty GM in town & very sluggish unless I step on the right pedal. In the hills its ok but will be so much sweet with my 5.29s & locker. Cant wait!
Old Feb 12, 2004 | 12:58 PM
mt_goat's Avatar
I bet you don't use your OD gear much with that huh?
Old Feb 12, 2004 | 01:19 PM
Yoter's Avatar
Guest
Nah its just a worthless button to me. Now the ECT button and me get along real well. It just thinks its funny to watch my gas guage drop like Martha Sterwart stocks. Please let my 5.29s get here tomorrow. I am getting impatient with all this talk of gearing.
Old Feb 12, 2004 | 03:32 PM
my95toy's Avatar
i went to an offroad shop and the guy said he's seen some broken rear ends with 5.29 gears. he recommended 4.88 for 33's. although the peps on this forum haven't seemed to have had any problems with 5.29s
Old Feb 12, 2004 | 04:29 PM
Cebby's Avatar
33's and stock 4.88's for 4 months or so now. I ran 32's for 85-90K miles with no problems. Although, MY 3.0 is a real powerhouse . It does just fine and its purty hilly here.
Old Feb 12, 2004 | 04:38 PM
Yoter's Avatar
Guest
Did he tell you they were all broken rears on toys or rigs in general. I would imagine it comes down to what kind of rig, engine size, how modified the eng. is, & size of tires. Dont most gear sales companies have lifetime warranty's on their gears?
Blue
