still seemingly no rear brakes
Old Aug 20, 2009 | 09:48 PM
Y2Krunner's Avatar
i just replaced the inner axel seals on both sides of my 98 runner. Changed the pads as they were so saturated in gunk it wasnt even funny. once everything was cleaned up and put back together, brakes bled and adjusted, it still feels like i have no rear brakes. the e-brake works good, i adjusted the brakes 1 tick back from slight grab when spinning the wheel by hand. tried reverse with the e-brake and didnt notice anything. i can jack up the rear end, spin the wheels hit the brakes and nothing happens until about 3/4 pedal depression when the brakes gently stop the wheel. Just a bleeding thing or what?
Old Aug 20, 2009 | 10:07 PM
vital22re's Avatar
totally a bro
i wonder if there is a proportioning valve for the rear like on the trucks. maybe your wheel cylinders are sticky? or shot?
Old Aug 20, 2009 | 10:17 PM
desertcamper67's Avatar
Are you jacking it up by the frame or the axle? It matters as you change the LSPV angle.
Old Aug 21, 2009 | 06:42 AM
fightman80's Avatar
I've got the same problem, after doing the seals!!
Old Aug 21, 2009 | 06:58 AM
Y2Krunner's Avatar
jacking up under the diff
Old Aug 22, 2009 | 02:12 PM
Y2Krunner's Avatar
how do i go about trouble shooting this? how to check the wheel cylinders?
Old Aug 25, 2009 | 05:34 PM
roundhouse's Avatar
3rd gens have a LSPV??????????
I have the same problem, where is the prop valve?
Im gonna bypass it & see what happens.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Cplmike
Jul 8, 2015 08:47 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
