Steering Shakes
Old Sep 6, 2018 | 11:14 AM
cryptkeeper's Avatar
Steering Shakes
I just picked up a 2000 4Runner SR5 its got 214,000+ miles , Drives nice in good shape , But as I Drive it , when I hit pot holes , Bridge Joints and speed bumbs the front end and Steering wheel shake , I was wounding if this has happened to any one and how you fixed it ?
Old Sep 7, 2018 | 04:50 AM
Malcolm99's Avatar
That sounds normal to me, but you can get play in the steering rack bushings, most replace them with Prothane or ES bushings and be done with it, might aswell replace the anti-sway bar links and bushings with prothane and ES bushings well your at it.
Old Sep 7, 2018 | 11:39 AM
aowRS's Avatar
In 414,000+ miles, I've replaced my rack bushings, sway bar end link bushings, upper ball joints, and lower ball joints multiple times. Additionally I've adjusted the steering rack at least a half dozen times and replaced the upper control arm bushings once.
Unless you know how well the truck was maintained, it could be one item, or the result of various worn components that were neglected for 18 years.
Andreas
Old Sep 9, 2018 | 01:30 AM
wyoming9's Avatar
Red face
Then we all have a different idea of a shake .
To me a Shake is when any thing in the cab not secured flies several inches into the air and keeps bouncing to things stop.
if your not paying attention the steering wheel gets yanked out of your hands
Old Sep 9, 2018 | 06:15 AM
Thanks for the input , I will check into that
A.Wilson013
May 1, 2010 09:49 AM
arielb1
Jan 3, 2005 08:06 PM
arielb1
9
Dec 4, 2004 07:43 PM
aiwaskiw
Mar 13, 2004 01:04 PM
