Steering box Removal?
Old Aug 1, 2004 | 06:13 PM
AKennedy87's Avatar
Today I was pulling my steering box to sell it off and got everything removed until I had to remove the pitman arm. The giant 1 1/4" bolt that connects the arm to the box wouldnt budge so next I went to the bolt with the cotter pin nut going into the steering linkage. I got the pin and nut off but the bolt would not come linking the two arms. Its one of those that is on a ball with a bushing between the two arms. Any advise on how to get this out? Your help would be greatly appreciated.
Thanks,
Alex
Old Aug 1, 2004 | 07:00 PM
AKennedy87's Avatar
I just read chiltons and it said to take that giant bolt off so I think I am goign to try to remount it somewhat and than crank that.
Should the threads be in the regular direction? (steering is crazy like that sometimes)
Old Aug 1, 2004 | 09:31 PM
Flamedx4's Avatar
The threads are in the "regular direction."
You need something called a Puller. I paid $6 for each for them and it takes the pitman arm and the rod end off in seconds. I needed two sizes, one for the rod ends and one for the pitman arm on the steering gear shaft. Like this: http://www.harborfreight.com/cpi/cta...emnumber=36861
You can also use a pickle fork, sometimes it's hard to get the puller to fit, and the pickle fork has to do. Also a really cheap too. Google for steering arm puller and picklefork, you'll get some how-to articles... This is a pickle fork: http://jtoutfitters.com/product/GRN25201
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
gillesdetrail
Aug 3, 2015 04:43 PM
Esibnitsud
Jul 30, 2015 08:19 PM
crashburnoveride
Jul 10, 2015 06:39 AM
