SS #1.2 lift installed (pics)
Old Apr 16, 2008 | 08:23 PM
ktincher's Avatar
Originally Posted by Rock Slide
Wow, looks good.
After reading your sig, your rig looks set to take on anything CO can dish out . Any plans for a winch or aux lights?
Not at the moment. As you probably know, one must let the bank account heal quite a bit before the next endeavor. I have plenty to play with at the moment.
Thanks for the comment!
Old Apr 16, 2008 | 08:27 PM
ktincher's Avatar
Originally Posted by Ron Helmuth
[new BFG A/T KO 285/75's. I have a little less than an inch separating the tire from the A-arm and after taking off the front mud flaps, I don't think I will have any rubbing problems.
nice shots thanks for posting them up. I am considering Sonoran as well and agree Steve over there is so helpful. You mentioned removal of the stock mud flaps and I am picturing that you are getting some interference with the new tires under compression or when making sharp turns.
I intend to stick with the LT265/75/16s and wonder if you feel those would present rubbing issues? Nitto Terra Grapplers(right around a 32" diameter)are what I am running. I want to stay with the stock mudflaps up front.[/quote]
Great to hear that you are considering the SS lift. I highly recommend it! As for the tires, the 265/75's won't be a problem, but if you do indeed lift you will definately want the larger 285's. They make a huge difference in overall look and stance. You will probably regret smaller tires if you go that route.
Good luck, post some pics when you get it all done!
Old Apr 16, 2008 | 08:31 PM
ktincher's Avatar
Originally Posted by osker fenix
ya i realized that after i took another look at the thread....and i dont even have a hitch on right now, my truck would look like a damn stinkbug....man i really want some LC's tho
Yeah, Steve at SS recommends that you have either a trailer hitch or custom bumper and sliders to keep your rear end down. Even with both bumper and sliders, it sits slightly higher in the rear. I expect about an inch of settling on the Land Cruiser coils though.
It's about 40inches from ground to top of wheel well in the back and about 37inches in the front......
So, go SS#7 OR get yourself a nice bumper!
Old Apr 16, 2008 | 09:07 PM
07sbock's Avatar
Yea I'am starting to build up my 98. Next you gotta get it scooped! All the cool people are doin it. Looks awsome!!
Old Apr 17, 2008 | 05:42 AM
  #25
Ron Helmuth's Avatar
thanks 2020
Originally Posted by 4Runner202020
you wont rub at all with the 265's. people run those without lift... i would really suggest the 285's
Yeah I had heard that -until I bought them I truly thought they would not rub, but apparently I do not have the tall 99 springs. I do have the rear sag and have been hauling rock over the last couple of weeks-which likely has not helped it out too much.
You favor the 285s just to fill out the wheel well or for other reasons?
Looks nice, one of my co workers just lifted his Tacoma and now may be able to have it bought back by Toyota on the frame rust issue. what a world....
Old Apr 17, 2008 | 05:46 AM
  #26
deines97runnah's Avatar
One word. Clean...........(for now?)
Old Apr 17, 2008 | 05:58 AM
  #27
toy_tek's Avatar
Looking good, man. Actually, with the exception of "5 speed" your sig looks almost identical to mine!
Time to put it all to the test... enjoy.
Old Apr 17, 2008 | 06:37 AM
  #28
mayfield's Avatar
i have one question for you; how did you get those front coilovers installed? man, i cannot for the life of me get the bottom of the coilovers lined up with the lower a-arm...any advice?
Old Apr 17, 2008 | 07:30 AM
  #29
Skrillah's Avatar
Yo man I understand, I don't how to lift it more than an inch up front. I don't know how to force that a-arm low enough without damaging the cv boot. I understand you have to disconnect the top sway bar nut and it helps to have a diff drop in but still. I guess I'm just afraid to keep cranking.
To push the a-arm down though, use the stock bottle jack, turn it upside down in the wheel well and start cranking. Make sure its secure though, the "piston" (sorry if thats the wrong term) on the jack tends to slip off that a-arm easily so if you put the head of the "piston" on the top bolt for your upper ball joint, it sticks good.
Back on topic though, I was curious how you liked the ride of the new system. I've heard its night and day difference between stock...? I currently run the HD Bilsteins all around and it seems really stiff and bumpy, hopefully those new 5100 series shocks are better? I'm thinking about upgrading and just getting a SS system but I don't know if there would be enough difference to constitute the cost!
Truck looks real good, you'll have to keep us posted on how some of the wheeling trips turn out! That is......take pictures!!
Old Apr 17, 2008 | 08:13 AM
  #30
mayfield's Avatar
I gave Steve a call at SS and he recommended that i perform the same task. pretty clever. i will give that a shot, and see how it works out. thanks for your advice!
Old Apr 17, 2008 | 11:25 AM
  #31
Boostin00's Avatar
Your ride looks really good. Looks like you'll be set for some off-roading! Good work man!!
Old Apr 19, 2008 | 01:52 PM
  #32
pattycakes77's Avatar
Originally Posted by ktincher
love that suspension bling! looks really nice! it keeps getting harder to keep up with the neighbors around here with posts like this
way to go kit!
icentropy
Sep 16, 2020 02:47 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
bryan34w
Jul 6, 2015 05:53 PM
