SR5 fender flare questions
Old Apr 10, 2007 | 04:41 AM
mkgarrison5's Avatar
Originally Posted by aowRS
After 5 years of ownership, I finally pulled off two of the stock rubber/aluminum fender opening trim pieces. I've wanted to do this each year in order to clean behind them. Well, I really should have. The pieces were packed with dirt and grit and the profile of the 'flare' had worn a faint mark into the fender from normal movement over the years. As soon as I saw the amount oif moist dirt that had accumulated, I made the decision to leave these off permanently. I managed to make the wear marks almost disappear with some cleaning and polishing, but they are still visible.
The fact is, these 'flares' are not going on again. I intend to keep the truck for many more years and have no desire to see rust forming behind these pieces. So the question is: do the slim, black plastic SR5 flares mount using the existing holes and adhesive? I'm thinking of the very low profile black textured ones that I've seen on a few SR5 models. Not the Limited flares, nor the semi-Limited SR5 flares.
I've searched and found nothing. At the moment, the truck looks newer. I'm not sure what it is - maybe the aluminum strip inside the 'flare' was starting to look dated
The truck as it looked a few days ago:
Andreas
YOU LIKE THOSE BRIDGSTONE DEULER AT'S??
Old Apr 10, 2007 | 02:45 PM
aowRS's Avatar
Originally Posted by 97Runner
how much for shipping to 35209 (AL) i might be callin dibbs here
PM sent.
Andreas
Old Apr 10, 2007 | 02:46 PM
aowRS's Avatar
Yes, and I just installed my second set. The first set were 275/70s and the second set are 265/75.
Andreas
Old Apr 10, 2007 | 02:55 PM
964runnerKY's Avatar
AOWRS,
The black SR5 flares will fit just like the chrome trim with no need to drill holes. I bought a set from a local junk yard and out of 8 4runners I was able to come up with a set for about $100.00. Try your local junkyards and you can find a set reasonible.
Old Apr 11, 2007 | 04:24 PM
  #25
97Runner's Avatar
PM sent.
Andreas
i havent gotten the PM?
Old Apr 12, 2007 | 10:51 AM
  #26
97 JRunner's Avatar
I am also interested in the SR5 flares if that also falls through.
Thanks
Old Jul 4, 2007 | 10:24 AM
  #27
Skrillah's Avatar
Send me a PM if these are still up for grabs, id take'em for sure.
Old Jul 4, 2007 | 01:15 PM
  #28
aowRS's Avatar
I finally tossed them....
Andreas
Old Jul 6, 2007 | 01:51 PM
  #29
skjos's Avatar
I could use the rear driver side flare if you still have them (mine has a small ding in it).
Sep 4, 2015 09:27 AM
skebe22RTE
Jul 31, 2015 02:03 PM
coffey50
Jul 28, 2015 10:55 AM
88yodabasket
Jul 13, 2015 01:32 PM
Cplmike
Jul 8, 2015 08:47 PM
