squeak in rear window
Old Sep 9, 2003 | 09:01 PM
Question squeak in rear window
I have a squeak in my rear window when i raise or lower it- 91 4runner. I have taken off the carpet on the rear deck and looked for obvious signs of the cause, and all I can see that may be the cause is rust along the lower metal casing of the window where the regulator tracks. I asked the Toyota dealer parts man if there is a common fix for this problem and he said the whole regulator usually has to be replaced- big bucks for a little squeak. Anybody know any tricks to stop the squeak or typical causes of this problem? It seems to squeak less when wet from rain. This must be a pretty common problem and annoyance for others out there- any input would be appreciated. thanks
Old Sep 10, 2003 | 04:38 AM
Yoter's Avatar
Guest
Frikkin stealership for yuh huh. Well I also have a 1991 4Runner and also have a squeek in my rear window. I have assumed it has been dry window tracks but have just been to lazy to grease them up. That is the fix for it I believe not replacing the whole regulator. I am actually surprised after asking them about the squeek why the dealership didnt say you need a new rig. Thats their style you know.
Old Sep 10, 2003 | 04:45 AM
Victor's Avatar
Mine squeeks but got a lot better after I used it frequently for a few months. Up and down a couple of times a day for a couple of months made it dead silent which I assume means the lube got redistributed. I should take mine apart and grease it though. I don't live in the rust belt but if you do don't hesitate to get on that project.
Old Sep 10, 2003 | 05:36 AM
TOR
Regulator
Well, if you can't seem to fix the noise here you go.
69801-89122 $85.16
Shipped to your front door, this doesn't include the motor for it though.
Todd
Old Sep 10, 2003 | 08:30 AM
CTB's Avatar
CTB
Ya, grease the window tracks both inside the tailgate and top part (where the window slides into the roof area). That should help your problem.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
