Sqeaking Belts, Sloppy steering
Old Jan 31, 2004 | 07:57 AM
data's Avatar
Senior Member
Squeaking Belts, Sloppy steering
Ok this squeaking belt is about to drive me nuts. Everytime I start up the rig, it will squeak forever until it warms up. Then I'll drive it down the street and I'll come to a stop and it'll start squeaking again. This there any possible way I can fix this myself? What's wrong with it? Also when I turn the wheel on pavement I get some slippage and it starts squeaking then. Sometimes the wheel slips really bad.
Old Jan 31, 2004 | 12:53 PM
data's Avatar
Senior Member
btt
Old Jan 31, 2004 | 02:59 PM
Fink's Avatar
I had pretty much this same problem without the sloppy steering...it was just that one of my belts needed to be tightened. Pretty simple fix, local place didn't even charge me for it
Fink
Old Jan 31, 2004 | 03:09 PM
toy283's Avatar
Which belt is it?
Old Jan 31, 2004 | 03:35 PM
data's Avatar
Senior Member
Originally posted by toy283
Which belt is it?
Ya know, I'm not really sure. I'm thinking the one that is attached to the ps pump. I get a really bad squeal when starting and also when try to turn on dirt while the rig is stopped.
Old Jan 31, 2004 | 03:59 PM
OneTrickToy's Avatar
Replace the belt. A temporary fix is to rub a bar of soap on the belt. That will quiet the belt down until you replace it.
Sloppy steering, check your tie rod ends, pitman and idler arms, if that all looks good, check your PS fluid level.
Old Jan 31, 2004 | 04:02 PM
toy283's Avatar
That almost sounds normal. It sounds like it is squealing when the PS pump is under the most strain. Now, either your steering gear (pump and/or gearbox/rack & pinion) is going (not likely) or it is the PS belt which needs to be tightened and/or replaced. This belt needs to be very tight, much tighter than an alternator/waterpump belt needs to be.
Old Jan 31, 2004 | 06:09 PM
data's Avatar
Senior Member
I think the power steering pump pulley may need to be replaced again. It has been replaced once before. It's making a loud noise again, so that might be the problem. I'm going to the dealership on Thursday, so I'll get them to check it out. I still have a couple thousand miles before my warranty is up.
Old Feb 1, 2004 | 05:06 AM
MTL_4runner's Avatar
Buy some belt dressing and spray it on the pulleys one at a time.
Then take it out and see if it still squeels....if yes try the next til you find the offender.
Then replace the belt and tighten to the correct tension.
I8URSVT
Sep 3, 2015 11:42 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
izzmee
Aug 17, 2015 10:20 AM
RBK
Aug 2, 2015 11:33 AM
WellsR
12
Jul 31, 2015 03:27 PM
