Speedo Question...
Old Sep 4, 2002 | 09:56 AM
madone's Avatar
Question Speedo Question...
I've been reading alot about your tires you guys have been upgrading to. In one of the post it mentioned:
"It will throw your speedo off the same percentage your tire size increases. So if you go from a 31 to a 32 your speedo will show 3% slower than actual."
So no I wondering...
I have a new '02 SR5 with the P265/70R16 tires.
Since these are stock, is my Speedo accurate? If not, how far is it off?
The difference with mine being, I never actually went up in size..they came with the 31's
Thanks
--Mark
Old Sep 4, 2002 | 10:24 AM
Yoda's Avatar
Hi Mark,
If those are the stock wheels and tires, your speedo should be accurate. A quick way to check it is with a GPS. Most newer ones will show ground speed in real time. Way cool.
My LC was not off as far as I expected. (31" tires, but I guestimated a correction and changed the speedo drive gear)
David
Dieselmann
Feb 19, 2019 02:57 AM
charlie_fong
Sep 27, 2015 10:06 PM
travisamorgan
Sep 2, 2015 01:00 PM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
