speed sensor wiring
Old Jan 1, 2009 | 03:51 PM
gornish_hick's Avatar
speed sensor wiring
I got a 96 4Runner 2.7 with a Manual Transmission and the wireds got pulled out of the vehicle speed sensor connector. I'm trying to match the 3 wires up with the connector. The slots on the Connector are numbered 1, 2, 3 and the wires are yellow/Black, Blue/Pink, Blue/white. Can anyone help me match these wires back up to the connector??
Old Jan 1, 2009 | 07:20 PM
97ltd4x4's Avatar
From my 98' EWD,I found vehical speed sensor located in the combo meter section...for 3VZ-FE, 3pin Black connector color:
pins look like this with the connector disconnected,pins facing you ..with the connector lock orientated up:
----{ LOCK}---
[ 123 ]
small notch on bottom to line up connector
pin1=B-Y black/yellow
pin2=P-L pink/blue
pin3=GR-L gray/blue
They match up with your colors except the pin 3...maybe they changed colors from 96 to 98'.....
Hope this helps...
Old Jan 2, 2009 | 08:18 AM
Thanks man, ill giver a try
sandyota
Feb 4, 2021 11:16 AM
BeMiceElf
Oct 10, 2015 09:40 PM
88yodabasket
Jul 13, 2015 01:32 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
