somethnig in cat. converter?
Old Aug 19, 2005 | 03:01 PM
Chapman88SR5's Avatar
is it possible for something to be stuck in the cat? theres something rattling down there and it sounds like its in the cat. its not a new cat either so its not like somethnig was in there during instalation
Old Aug 19, 2005 | 03:02 PM
Silver_Truck's Avatar
its probably your heat shield...thats what it was on my truck when it soudned like the cat was rattling.
Old Aug 19, 2005 | 03:04 PM
lol dont you find it funny when you think your on to something complicated but yet it turns out to be the most simple thing ever?
thanks ill look at that
Old Aug 19, 2005 | 03:12 PM
Rivalred's Avatar
Agreed...
Old Aug 19, 2005 | 03:14 PM
4x4Lamm's Avatar
might be the internals though to...
Lamm
Old Aug 19, 2005 | 09:31 PM
Fink's Avatar
My buddy had an extremely clogged cat on his truck and he heard a rattling, he removed the heat shield and the sound was still there, so he replaced the cat and asked the exhaust shop to let him have his old one. He took it home and cut it open...turns out the buildup on the sides of the cat had come loose and were rattling around in there...odd, but I guess it can happen.
Fink
Old Aug 19, 2005 | 09:33 PM
hm, how can i tell if its clogged?
Old Aug 20, 2005 | 08:04 AM
Fink's Avatar
You would probably notice a loss in mileage, nothing huge but a difference nonetheless. The way I could tell on my old rig was driving around at night and then stopping with the rig running, the cat was glowing red it was so hot...usually a good sign something isn't right. lol.
Either that or on my 3rd gen it triggered the CEL.
Fink
Old Aug 20, 2005 | 11:32 PM
84sr5yoty's Avatar
Using vacuum gauge is the easiest method.
Starting with the engine at idle, slowly increase engine speed to 3,000 RPM, engine vacuum should be equal to or higher than idle vacuum at 3,000 RPM. If vacuum decreases at higher engine RPM's, an excessive exhaust back pressure is probably present.
Old Aug 21, 2005 | 12:37 AM
rocket's Avatar
This is what i've been told by a few guys at muff shops and others: Knock on it with your fist. If it makes an obvious but unusual internal rattle, it needs to be replaced.
kawazx636
Oct 6, 2021 03:03 PM
coryc85
Dec 5, 2015 08:42 AM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
