skid control and center diff lock...this happen to anyone?
Old Feb 6, 2006 | 10:06 AM
BADLNDS's Avatar
While wheelin' in the snow yesterday...I had locked the center diff in my 4Runner (2002).
...went around a corner and slightly fish-tailed and the skid control activated and the light came on??? (yet the VSC OFF light was on)
what gives?...I thought when u lock the center diff it turnes off all the electronic aides?
is this normal?
-B
Old Feb 6, 2006 | 11:02 AM
eric-the-red's Avatar
Locking the centre diff turns off the VSC, but doesn't turn off the traction control or ABS.
Old Feb 6, 2006 | 11:05 AM
hillbilly's Avatar
↑ Bingo! And unfortunately, yes, its normal. To my understanding, the only way A-Trac can be completely disable is with the T-case in 4Lo and the tranny in Lo (1st gear). Or you can do the AndyMod to manually disable it.
Old Feb 6, 2006 | 11:17 AM
BADLNDS's Avatar
will be doing the andymod asap!
thanks,
-B
Old Feb 6, 2006 | 06:06 PM
aowRS's Avatar
Thanks - my fame grows with each installation of my AndyMod!
Andreas
Old Feb 11, 2006 | 07:12 PM
rock4200's Avatar
help
did any one do this mod i hate the traction control i had my 02 locked tonight trying to get up my driveway in the ice and snow and all that kept happening was eerrr errr err on my brakes and pulsating followed by a beeping noise what good is a locker if this &*%^ keeps happening i couldn't even get up the driveway i would like to perform this mod just wanted some reasurance
Old Feb 11, 2006 | 07:20 PM
aowRS's Avatar
Your '02 does not have a locker. You have open diffs with traction control (TRAC) and vehicle stability control (VSC). Both of these systems rely on the ABS to function. When you depress the 'center diff lock' button, you are simply forcing the truck to send equal amounts of torque to the front and the rear. At the same time, the VSC is deactivated. But the TRAC stays active.
The beauty of my "AndyMod" is that by flipping one switch, you disable all of these systems and are able to power your way through the bad stuff in the traditional manner - wheelspin The AndyMod can be engaged in 2WD, 4WD, and 4WD with center diff locked.
This is a very easy mod that should take about 30 minutes to install once you've assembled the wire, a switch and a few connectors. Do a search here to find many posts on the topic.
Andreas
Old Feb 12, 2006 | 11:25 AM
BigJohn's Avatar
cant you just pop open the hood and unplug some cable i remmber seeing a pic of
Old Feb 12, 2006 | 02:15 PM
aowRS's Avatar
Yes.
Andreas
Old Feb 12, 2006 | 04:12 PM
lee's Avatar
lee
thats andreas' pic
88sasturbotoy
Jan 30, 2026 01:57 PM
BeMiceElf
Oct 10, 2015 09:40 PM
yourrealdad
Jul 29, 2015 11:08 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
