signal and hazards dont work.
Old Nov 27, 2004 | 06:49 PM
kevin444's Avatar
Well after i finished installing my electric fan with hit and miss sucess it's finally working properly. But in return my turn signals and hazards dont work. As far as what ive done prior to this wierd problem. Was install the fan. Ran a wire through the firewall through the rubber grommet hole through the driver side. Had the wire for the fan tapped onto the acc line behind my stereo. Thats pretty it. I took a quick peek at the fuses and they seem fine but i guess it doesnt hurt to take another look. Anyone have any more suggestions? relays?,fuses?, frayed wires?, loose connections? im lost.
Old Nov 27, 2004 | 07:13 PM
Brendan's Avatar
be 100% sure that it's not a fuse. nothing worse than troubleshooing for hours and hours only to find that the solution was the easiest and most obvious one to begin with.
Old Nov 27, 2004 | 08:50 PM
kevin444's Avatar
Im sorry what would that be.
Old Nov 27, 2004 | 09:06 PM
ekim121's Avatar
They're saying the most obvious is a fuse being blown...my guess would be that you have a short somewhere in there...and it could be a huge pain in the behind to hunt down. So, I mean there isn't really much to say other than to check the stuff around where you routed the wire. In addition, if you unhook the fan does that affect the operation of your other things?
Old Nov 27, 2004 | 10:04 PM
jimbo74's Avatar
i would check the fuse
Old Nov 28, 2004 | 07:24 PM
kevin444's Avatar
Fuses look good. My neighbor said it has to be the relays inside the dash area? Could he be right?
Old Nov 28, 2004 | 08:25 PM
-ToYoTa-'s Avatar
i guess it would have to be a relay... you have to have the relay to open and close the circuit to cause it to blink
Old Nov 29, 2004 | 01:28 AM
L33T35T 4Runner's Avatar
you check the blinker fluid?
sorry
Old Nov 29, 2004 | 08:59 AM
KevyWevy's Avatar
yeah, you definetly need to check the blinker fluid!!! hahahahaha
but seriously, did you check the fuses that are in the engine compartment as well? does your interior lights work?
Old Nov 29, 2004 | 09:36 AM
kevin444's Avatar
yup all fuses good lights work.
Old Nov 29, 2004 | 10:45 AM
midiwall's Avatar
Just for kicks, try disconnecting the power lines (the ACC line and the constant 12v) to the fans and see if the lights start working... Just pull the spade lugs at the controller box, that''l be easier than trying to get back under the dash.
Past that, check the flasher itself which I think is sitting up behind the fuse block inside. It's a little module that pulls out.
Old Nov 29, 2004 | 11:02 AM
li_runner's Avatar
I'll throw out a guess did you connect the hazzard light button when you put the dash back in? That could be the cause.
Old Nov 30, 2004 | 04:27 PM
kevin444's Avatar
i never touched the hazard button area for the last or so 3 weeks.
Old Nov 30, 2004 | 04:28 PM
kevin444's Avatar
I unhooked the controller box and that doesnt seem to make the hazards work nor headlights work but my actual acc line is hooked up to a relay Ill try disconnecting them all together tmrw morning and see what happens.
Old Nov 30, 2004 | 04:29 PM
kevin444's Avatar
interior lights work headlights work backup lights works. It's pretty much those 2 damn things the signals and hazards.
Old Nov 30, 2004 | 04:36 PM
midiwall's Avatar
Okay, hang on...
You had said:
Originally Posted by kevin444
interior lights work headlights work backup lights works....
Right after saying:
I unhooked the controller box and that doesnt seem to make the hazards work nor headlights work...
Is this a brain fart , or do you mean that when you unhooked the controller box that the headlights stopped working?
My wondering about the signal box is if you've got a weird load on the wrong part of the electrical system and there's not enough current flow through the flasher to blink the lights. So if you DO mean that the headlights stopped working after disconnecting the controller, then something's drawing a lot of current.
Did you get a chance to check the flasher unit itself?
Old Nov 30, 2004 | 04:38 PM
kevin444's Avatar
im sorry the signals and hazards basically no effect whatsoever with the disconnection.
I had a brain fart dawg.
Old Nov 30, 2004 | 04:46 PM
kevin444's Avatar
I'd like to add i also kinda hosed down the entire engine bay becuase i was being stupid and mad cuz i opened the rady cap right after i drove around and well the radiator was acting like a volcanoe for about 15 secs. So i got the hose just to hose down all the rady residue off the engine compartment. But i doubt it would cause any problems I mean i did give it time to dry.
I'm not sure but one day while i was driving inside the cabin I smelled a very mild burning electric smell. I wasnt sure if that was something outside or inside the cab it seems pretty wierd i ask.
Old Dec 2, 2004 | 08:52 AM
kevin444's Avatar
le bump
Old Dec 2, 2004 | 08:59 AM
midiwall's Avatar
le bump
Did you le check the le flasher?
You're looking for something like this:
http://www.trustmymechanic.com/parts...al_flasher.htm
