Shifting into 1st
Old Feb 12, 2006 | 09:57 AM
jeremys73's Avatar
Shifting into 1st
Just a question.. My 98 4runner (auto) shifts good and solid when shifting into reverse, but when shifting from -Park- to -1st-, it does it VERY gently (you can barely tell most times). Sometimes it hesitates for a second before going into 1st. Is this normal?
Sometimes it shifts solidly into first but usually when its cold.
Old Feb 13, 2006 | 04:12 PM
jeremys73's Avatar
*bump*
come on, I know someone here uses first gear
Old Feb 13, 2006 | 04:21 PM
Jeffires's Avatar
You mean the shifter slipping into the 1st position, or the feel of the actual transmission engaging the gear?
Old Feb 14, 2006 | 07:41 AM
alotawatts's Avatar
I think he's
Sounds like he's descibing a delay between the time he selects ' D ' and the time he feels it engage. I have the same symptom with my Honda Civic auto. I suspect a clutch pack is bad. I have tried flushing the trans etc. Maybe a linear solenoid ? Automatics are a mystery to me........
Old Feb 14, 2006 | 03:32 PM
jeremys73's Avatar
yeah, when it actually engages into first gear. It just seems so smooth, unlike going into reverse. There is a defenite engagement when going into reverse. But going into first, I can't even feel it go into gear... stupid autos... I have never trusted automatics...
Old Feb 14, 2006 | 03:46 PM
SnoViking's Avatar
the reverse gear could be a differnent design also. Most likely the forward gears, including 1st are conical gears (correct term?) while your reverse gear is most likely a straight cut gear. Straight cut gears are louder. Im not sure but that might help. Also, I know cotman transmissions which is a national brand has free trouble shooting and estimates... try them
Old Feb 14, 2006 | 04:12 PM
Jeffires's Avatar
I've always felt mine go into R or 1, but after adding the Lockright to the rear differential, there is a very noticable thud and you can feel it engage. I'm not very fond of automatics either, but I take good care of mine. I want to see how long it will last, after it goes out, I have the manual tranny ready to take its place.
MaK92-4RnR
Oct 28, 2015 02:45 PM
runnermedic
13
Sep 21, 2015 05:20 PM
yoterr
Sep 15, 2015 06:26 AM
icentropy
Sep 10, 2015 05:03 AM
Badfish740
Sep 4, 2015 04:21 AM
