shackle flips
shackle flips
I was looking into shackle flips as a cheap way of lifting my truck. Has anyone ever done them? Also, what would i do for the IFS to match the lift from the shackle flip?
By "shackle flip" are you referring to a longer that stock spring shackle in back? If so, then yes that will give you some lift:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml
For the front end, ball joint spacers are a common way to get an inch or two of lift:
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
thanks man
if the shackles give me 3 inches of lift, and the spacers only give me 1.5 inches, can i stack more than one to even it out, or should i just crank on the torsion bars?
Shackles 2"-3" longer than stock will only give you about 1.5" of lift. See the following page for a detailed explanation:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
You can crank up the torsion bars a bit over the 1-5/8" ball joint spacers, not a whole lot, as you will run into limits on ball joints and steering rod ends. If you want more lift than 1.5"-2", then a mild body lift can be "stacked on top", so to speak, to give you more height:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
scott90
Oct 4, 2015 09:21 AM
sonorn67
Sep 19, 2015 05:39 PM
