Service history?
Old Apr 8, 2007 | 02:49 PM
fenrisx's Avatar
Service history?
When I had my 2004 Tacoma I could log into SETF.com to check the payoff on my loan, see recommended service, schedule a service.. just do lots of different things...
So yesterday I got the 2000 4Runner with 145k miles.. went and added this vehicle to my account.. and seen the 'check service history' button. When I did this the only service that was listed was ..
Automatic transmission service, and scheduled mile service. This was done March of last year. Then a month later it was sold to the guy in which I bought it from.
What is the 'scheduled mile service'? It had 122k on it at that point. Does that include timing belt? The man I bought it from said the timing belt had been replaced, but I'm not so sure really..
I've got a squeaky belt or something.. and I thought about taking it to the local Stealership and having them replace all the belts, and everything else you usually do when changing the timing belt.. just wasn't sure if I should jump the gun on that(not sure of the cost of the stealership doing it)..
Old Apr 8, 2007 | 02:51 PM
fenrisx's Avatar
I found this there as well.. so I guess I answered my question about the 120kmile service.
120,000 Miles or 96 Months
Replace engine air filter
Replace engine oil and oil filter
Replace engine coolant
Rotate tires
Replace limited-slip differential oil (Highlander, Land Cruiser, RAV4)(If vehicle is equipped with limited-slip differential)
Replace spark plugs (all models)(Required under the terms of the Emission Control Warranty)
Lubricate propeller shaft (all 4WD except Highlander and RAV4)
Lubricate wheel bearings and drive shaft bearings (Land Cruiser)
Re-torque drive shaft bolt (Highlander, 4WD RAV4)
Re-torque propeller shaft bolt (all models except Highlander and RAV4)
Inspect the following:
* Automatic transmission fluid
* Exhaust pipes and mountings
* Ball joints and dust covers
* Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
* Brake lines and hoses
* Brake linings/drums and brake pads/discs
* Charcoal canister (all models except Highlander and RAV4)(Inspect at 120,000 miles or 144 months, whichever comes first. Required only for vehicles in California, Massachusetts and New York).
* Fuel tank cap gasket
* Manual transmission oil (Tacoma, Tundra)
* Drive belts
* Drive shaft boots (Highlander, Land Cruiser; RAV4; 4WD Tacoma, Tundra and 4Runner)
* Rear differential oil (all models except 2WD Highlander and 2WD RAV4)
* Engine valve clearance
* Steering gear box
* Front differential oil (4WD models, Highlander, RAV4)
* Steering linkage and boots
* Transfer case oil (4WD models)
Additional Maintenance Items for Special Operating Conditions:
Inspect nuts and bolts on chassis and body
Replace air conditioning filter (RAV4)
Replace front differential oil
Replace rear differential oil (including limited-slip)
Replace transmission fluid or oil
Replace transfer case oil (4WD models)
Old Apr 8, 2007 | 11:12 PM
DSN46's Avatar
If the Timing Belt has been replaced (at least at the Dealer), there will be a sticker on the Timing Belt cover that has the date and mileage it was done. The mechanic who did it will also have his initials on it.
Just one way to check to be sure....
James
Dale Johnston
11
Oct 31, 2015 10:22 PM
Boomer8404
Sep 24, 2015 01:12 PM
PBRaddict#1
Sep 22, 2015 07:50 AM
Boomer8404
Sep 20, 2015 06:15 PM
Scatterbrain
Sep 3, 2015 06:46 PM
