seafoam treatment question
Old Sep 1, 2011 | 01:42 PM
  #41
Texas_Ace's Avatar
Originally Posted by swerks
Any one know if you can use the seafoam rx on a turbo motor or will it mess up the turbo??
How would it mess up the turbo?
Long as you don't put it in the oil which i don't recommend anyways you will be fine, i do it to my turbo cars all the time.
Old Sep 3, 2011 | 09:22 AM
  #42
swerks's Avatar
I thought it might leave some kind of residue or deposits on the fins of the turbo ???
Old Sep 3, 2011 | 12:04 PM
  #43
Texas_Ace's Avatar
Nah, the turbo gets so hot the next time you get into boost that anything would get burnt off in short order.
Old Sep 29, 2011 | 04:14 AM
  #44
hrt4me's Avatar
Originally Posted by Texas_Ace
Running it in the gas gives you a fraction of the benefits of running it in the intake. That's where it really does the magic.
Also don't run it in the oil, not a fan of that.
why not the oil?
Old Sep 29, 2011 | 04:17 AM
  #45
Texas_Ace's Avatar
Originally Posted by hrt4me
why not the oil?
Too many chances it could hurt something in the oil IMO. In the gas and intake it is basically impossible for it to hurt anything. There is a chance in the oil. Plus when you do it in the intake you do get some in the oil anyways.
Thats why you need to change your oil after doing the treatment.
Old Sep 29, 2011 | 05:48 AM
  #46
93toyrunner2's Avatar
In my experience it works great. I had a fouling injector on my 3VZE, so I removed the plenum to replace the injector. I noticed that the lower intake had built up carbon deposits that would not come off without some severe wire brushing. Not having the time on this particular weekday, I fixed the injector, and reinstalled the plenum. I injected half a can of SeaFoam, waited 15 minutes, and cranked it back up to blow out a huge cloud of smoke. There was still something wrong with that injector, so I pulled the plenum again. Upon inspection, the entire lower intake was clean, carbon that would not come off without severe scraping was gone. I used a rag to wipe of the remaining residue, and was immediately a fan of SeaFoam!
Old Nov 12, 2011 | 03:30 PM
  #47
jswizz's Avatar
Just wondering if a oil change is needed after the intake of seafome in the vacume line . Is it a must . JUst ran some through mine and was wondering THANKS.
Old Nov 12, 2011 | 03:58 PM
  #48
Texas_Ace's Avatar
If you only ran 1 treatment though the intake you should be ok. If you did it a few times and the water then the oil change is a must.
Old Nov 12, 2011 | 04:52 PM
  #49
jswizz's Avatar
Thanks TexasAce . also just checked my oil and it was a little brown and runny so I just did the oil change , thanks for the input !!!!!!!!!!!
Old Aug 10, 2016 | 03:26 AM
  #50
ErikZ1220's Avatar
Originally Posted by mwc0404
so the treatment works well then? Any noticeable difference?
So, I wanted to share my Seafoam story..
I had the head gaskets done in my 04 Sport about 3 years ago.. Ever since then I would have low oil pressure at start up and the oil light would come on. I thought at first that it was gunked up from something dislodging during the head gasket job. THEN, worst case scenarios were playing through my head that maybe my oil pump was well on it's way out..
This past week, I was ready to cut the cord, count my losses and get rid of it..
But as a last ditch effort, I tried the Seafoam - 2 bottles into the vacuum hose at the intake, 6oz in the oil and the rest of that bottle in the gas tank..
No more low pressure at start up, not even a little bit... Idle is MUCH MUCH better!!!
I think this $h_t saved my truck, and my pocket!
Old Aug 10, 2016 | 05:11 AM
  #51
ThorInc's Avatar
I personally have had good experiences with it as well with no ill side effects. Keep us posted as your improvements were quite significant.
Eggslinger
Jun 8, 2019 03:32 PM
accuracy
Aug 4, 2015 08:05 PM
makemusic116
Aug 2, 2015 05:23 PM
jjccamis
Jul 9, 2015 04:00 PM
