Rust spot repair
Old Jun 22, 2003 | 07:29 AM
tystoy's Avatar
Rust spot repair
I have a rust spot on the bottom of my drivers door. It isn't much bigger than a nickle. I was wondering if anybody could tell me the best way to stop the rust untill I get my paint job. The rust is not throught the metal but I don't think it will be much longer before it get that far.
Old Jun 22, 2003 | 07:36 AM
from what a friend(shop owner) tells me, you scrape the rust off by using a small screwdriver and also take out the paint that easily chips away then cover it up with touchup paint. That stops the rust from spreading.
Old Jun 22, 2003 | 08:08 AM
Bean's Avatar
I'm doing a little of this myself...
Cut some sandpaper down to 1/2 squares (maybe even a little smaller). You may want to be prepared with a couple different grits.
Get a bunch of pencils WITH erasers on one end.
Lightly glue the sandpaper squares to the erasers and roll the pencil back and forth between your fingers while pressing the eraser (sandpaper) against the rust spot.
This works great and minimizes an additional damage you might do by scrapping at it, but it might take a while if the rust is deep.
Use a rust converter and primer before putting touch up paint back on top. If you paint over 'live' rust you'll just make it spread faster.
Old Jun 22, 2003 | 10:14 AM
tystoy's Avatar
What in the world is that? like Bondo?
Old Jun 23, 2003 | 07:01 AM
Mr. Thompson's Avatar
I believe muriatic acid will dissolve the rust. Should be available in the autobody section of any parts store. Just make sure to rinse it off with water before shooting primer and paint.
Old Jun 23, 2003 | 08:55 AM
mtnfreak's Avatar
Rust converter - products like Extend, POR15, etc - deoxidizes any left over rust to help keep it from spreading.
Note: when you think you've gotten all of the rust off, keep going. If you buy any under a rust converter or paint, it will only get worse. You'll know if you've missed any a year from now when blisters start forming under the paint near the repaired area.
89fourrunner
Feb 17, 2016 06:52 AM
mdev126
Oct 4, 2015 04:48 AM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Sep 4, 2015 09:27 AM
58rennur4
Aug 4, 2015 08:49 AM
