running hot
Old Jul 6, 2004 | 11:18 AM
cmuspt45's Avatar
running hot
i have a 2000 tacoma prerunner v6, and here recently the needle on the temp gauge moved slightly above the middle where it normally sits.the truck is still running fine,but should I be worried? what might be causing this?
Old Jul 6, 2004 | 11:23 AM
rimpainter.com's Avatar
Please describe the driving conditions you are seeing this change under.
Towing, idling, freeway driving, city driving, all of the above...what?
Old Jul 6, 2004 | 11:29 AM
cmuspt45's Avatar
all of the above.
Old Jul 6, 2004 | 11:37 AM
1. Inspect the area of the water pump. Check for leaks.
2. Test or replace your radiator cap
3. After running the vehicle to "normal" operating temp, shut it down and immediately try to spin the fan. It should not spin easily.
Any recent changes/mods/maintenance work on the vehicle?
Old Jul 6, 2004 | 11:41 AM
cmuspt45's Avatar
no, totally stock.
Old Jul 6, 2004 | 04:25 PM
rpeAMP's Avatar
Definitely check the water pump. Mine started to leak causing the temperature to creep up slightly. Luckily I caught it and I had it replaced ASAP at the dealer.
Old Jul 6, 2004 | 08:47 PM
And you should still be under the 5 year 60K powertrain warranty (assuming your mileage is below 60)
the1998sr5
15
Jul 14, 2020 08:35 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
HRDC0R19
Jul 5, 2015 06:43 PM
