running boards are off, not sure what to do with the hole?
Old Jan 7, 2008 | 09:21 PM
Sloan's Avatar
how long does it take to do this...i'm not sure if i want to do it to mine yet or not.
and i like your limited flares.
Old Jan 7, 2008 | 09:26 PM
Elton's Avatar
can of expanding foam
Old Jan 7, 2008 | 09:38 PM
rdang's Avatar
Took about an 45 minutes to an hour - I love it without the running boards, although it does make the 4Runner look a bit smaller.
Old Jan 7, 2008 | 09:41 PM
Sloan's Avatar
to me it makes it look like it sits higher..
thats the only reason i want to take mine off
Old Jan 7, 2008 | 11:26 PM
  #25
rdang's Avatar
That is brilliant! I think the foam getting wet may cause some sort of weird mold though... but it was a good idea.
Old Jan 7, 2008 | 11:31 PM
  #26
rdang's Avatar
Also, I took mine off because I have rock sliders I need to put on still, but yeah, does make it look much higher.
Old Jan 7, 2008 | 11:33 PM
  #27
Elton's Avatar
im pretty sure its water proof
Old Jan 8, 2008 | 01:31 AM
  #28
nick_8787's Avatar
Duck Tape? Just a thought.
Old Jan 8, 2008 | 06:45 AM
  #29
hross14's Avatar
Originally Posted by trd_4runnin11
Well, the fender flares are connected to the cladding, and there are holes in the body panels behind the flares and cladding. So unless he wants to have a bunch of holes going around his fenders and above his rocker panels, then I'd leave the flares on.
I looked into this as well because when I got my limited I didn't really like the limited flares. I figured .."No problem, I'll just take em off." Only to find out that it is not really that easy.
There are holes in the Clading, yes, but you leave those bolt in there to hold the plastic wheel well liner in- Any other holes go right through the fender lip and are painted.
I have two 4runner like this--i can take pics if you would like.
Old Jan 8, 2008 | 06:53 AM
  #30
dirtoyboy's Avatar
I just left it open....i cant see the plastic rusting out that much
Old Jan 8, 2008 | 06:59 AM
  #31
rdang's Avatar
Yeah, not worried about the plastic rusting out , it's the metal above it... but some of you made a good point to leave it open to let it drain. I guess if you seal it and water gets in there from somewhere else, then problems would be worse.
Jun 1, 2021 01:51 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
smiley52
Jul 11, 2015 05:16 AM
skoti89
Jul 8, 2015 12:05 AM
toyota32
Jul 6, 2015 05:42 PM
