Rotational driveshaft play?
Old Apr 12, 2005 | 08:32 PM
Yamaha+Toyota=Fun's Avatar
I just noticed today that when my truck was in neutral with the Ebrake on I could slightly rotate my drive shaft. Do your guy's truck do this also? I am a bit concerned that my gears that I recently put in were not setup correctly and I want to know if I should take em out or not.
Thanks
Old Apr 12, 2005 | 09:03 PM
89_4runner's Avatar
You'll be able to rotate the driveshaft a little back-and-forth when the trans is in neutral. I've never changed the ring and pinion, but the rotational "slop" has been there a long time.
Old Apr 12, 2005 | 09:25 PM
superjoe83's Avatar
your just feeling the play between the axle splines and differential gears, how far can you turn it?
Old Apr 12, 2005 | 09:57 PM
maybe a half an inch? Im not exactly sure.
Old Apr 13, 2005 | 11:33 AM
I dont think its the play between the splines but I could be wrong. On the 3rd that I just pulled out I can hold the ring gear and slightly turn the pinion flange. Before I put the 4.88 3rd in I could hold the ring gear and turn the pinion flange quite a bit more. What is this play called? Is it gonna mess up my 4.88's?
It seems now with these gears in, there is a klunking noise that I can hear when I push the clutch in going up a hill or something that puts a little more tension on the driveshaft. I can also make the klunk when I a crusing and I lightly tap that gas a few times. Im worried....
punks_is_4x4
Feb 26, 2016 04:29 PM
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
Odin
Sep 26, 2015 06:56 PM
