Rims!!
Old Jul 4, 2004 | 12:46 AM
foodawg1982's Avatar
Rims!!
I was wanting to Buy new chrome rims. I was wondering if anyone can give me a recommendation. I have a 2001 3rd gen sport. I was thinkin 18's or 20's. I am a bit concerned about getting bad rims that could vibrate due to a bad fit. What do you think? any brands in particular? Sizes?
Old Jul 4, 2004 | 09:56 AM
X-AWDriver's Avatar
So,I take it you don't off road much but if you're 4wd then avoid anything over 17 inch unless it's the "bling" you want.
Sorry but big wheels on a 4wd is just dumb IMO and definetly is starting to be played out,spend your money on functional mods.
Old Jul 4, 2004 | 10:01 AM
Vato Loco's Avatar
20's are small now, get 22" or more
Old Jul 4, 2004 | 03:05 PM
Jason B's Avatar
I wouldn't go anything over 18's. The 3rd gen body doesn't look right with anything bigger. It's too skinny for anything over 20. To me it's like an explorer with 20's+ and it just doesn't look right.
Be it an escalade or navigator (wide and beefy), for sure 20's and up.
I'm running 16x8's which I think is the best of both worlds for me. I just wanted mine to still look beefy, yet flow.
Old Jul 5, 2004 | 06:59 AM
gn86r's Avatar
what does your budget look like? i have 22's and i dread the day my tires wear out. at $300 per tire its not really a good idea. i would go with a 20" wheel, if i had to do it again, id probably do a 20" bbs, like what comes on the trd sequioa or the 20" enkei wheels that come on the double cabs tundras. thats just my opinion.
Old Jul 5, 2004 | 10:12 AM
reply
My budget is under 2k...
Old Jul 5, 2004 | 01:55 PM
gn86r's Avatar
start looking for 20s... or a used set of 22s... make sure the wheels have the 108mm center bore, alot of the 6 lug chevys will have the same bolt pattern, but does not have a big bore hub center. good luck!
Old Jul 5, 2004 | 08:45 PM
thanks mann i heard alot of peeps having problem with the bore being too large ill start looking for a 108mm bore
Old Jul 5, 2004 | 08:48 PM
108mm bore is for the 2001 4runner sport right?
Old Jul 5, 2004 | 08:57 PM
Supercharged's Avatar
Get you a set of Boss ( by American Eagle ) Series 301 w/ Superfinish. These look good and you won't have to worry about them peeling like chrome wheels. They are perfect for someone with a budget. The warranty is fantastic- I know because I used to work for them. They come in both 20 and 22s. I have a set on my 03 dcab
Old Jul 5, 2004 | 11:29 PM
do you got a pic of your ride with rims?
Old Jul 6, 2004 | 05:38 AM
gn86r's Avatar
most of the newer toyota 6 lug trucks are 108mm bore. tacoma, sequoia, tundra and the 4runners all use the same bore. i have seen the boss wheel, imo they look pretty good and are price well also. but, i havent seen them in a 22" wheel.
Old Jul 6, 2004 | 06:12 AM
RLJSlick's Avatar
Vato, what are those tires you have on your web site? Are those stock size tires, or are they larger?
Old Jul 6, 2004 | 06:32 AM
I will post some pix ASAP. By the way, I was mistaken about the sizes; the 301s comes in 20 an 23s- not 22s.
Old Jul 6, 2004 | 12:33 PM
Xpresident's Avatar
antera 301
hey i've got 20's wrapped in pirelli's....i've wanted to get 22's now or either lower my 4runner. Not sure on what to do, but i would go with 20's if yo'ure budget is under 2k....and you can get any chevy rims that are 6 lug, you just have to take them to a machine shop and have the center bore drilled out to 108mm and a depth of 3 inches. I used wheel spacers as well so i wouldn't have to drill further into the wheel and possibly mess up the structural integrity of the wheel....
Old Jul 6, 2004 | 04:13 PM
dbikeman's Avatar
Why do you need a depth of 3". When I was out measuring it looked like i only needed about 1/2 and in to make the wheel flush like its supposed to be. What did they charge you to drill them out as well?
Old Jul 6, 2004 | 04:18 PM
Xpresident's Avatar
it might have been a little shorter than 3" can't remember, they did it over a year ago, i'd have to take off one of my rims and measure it to be exact. but i used wheel spacers so i would have to drill out less of the rim. they charged me $250 for all four wheels.
Old Jul 8, 2004 | 06:19 PM
Here's a pic of my truck.
Old Jul 8, 2004 | 08:29 PM
Yosmany's Avatar
You mean these Enkei 20's
Old Jul 8, 2004 | 09:48 PM
dbikeman's Avatar
How much are those 20s?
