RightTurn Signal
Old Dec 20, 2003 | 04:58 PM
ts1's Avatar
ts1
RightTurn Signal
I noticed today that if I put on my turn signal that it blinks at 3X the speed of normal. I immediately thought that one of the bulbs must be out but when I checked all the lights and the lights and rear brake lights are fine. The front as well. The problem is also intermittent. I have observed that sometimes when I put the right blinker on, it starts fast and then slows to normal. Any ideas where there may be a bad connection and where I should look?
Old Dec 22, 2003 | 02:17 AM
Tacoma Dude's Avatar
Whoa, that's a strange problem to have.
I have no idea how to help you, buddy - but here's a bump for you before the post gets buried!
BUMP!
Old Dec 22, 2003 | 03:56 AM
ugadawg95's Avatar
I would pick up a couple of bulbs and try replacing them just to see if one of them is about to go out. I have noticed that if a bulb is about to go this could happen...it did in my Civic one time. Good luck!
Old Dec 22, 2003 | 04:53 AM
SLC Punk's Avatar
It could be a wire that is exposed. So when it grounds out it will blink fast, and when it isn't touching the metal, it is ok..
Old Dec 22, 2003 | 07:17 AM
hungryStu's Avatar
Loose ground post would be my best bet.
-Stu.
kawazx636
Oct 6, 2021 03:03 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
calderp
Nov 16, 2015 02:49 AM
Scotttekoch
Sep 28, 2015 10:30 PM
Boomer8404
Sep 24, 2015 01:12 PM
