This Is Ridiculous
Old Dec 19, 2004 | 06:01 PM
4x4Lamm's Avatar
This Is Ridiculous
Well, it was my towns first BIG blast of cold and snow today.
I also had a problem with the 4Runner. It was so cold it wouldn't start!
I have an almost brand new OEM ignition (plugs, wires, cap. rotor, coil and module) and good fuel preassure.
Asside from a block heater, what can I do? I'm going to switch to a lighter oil like 5-W30 but other than that, what could be broken, worn or wrong with my 4Runner that it simply won't start in the cold. i get plenty of long slow cranke, but it just won't turn over. I love the snow, but I hate the fact that my neighbors Kia Rio fires right up and I'm just sitting there cranking and running my Optima down.
Any ideas? Help...
Thanks,
Lamm
Old Dec 19, 2004 | 06:03 PM
kyle_22r's Avatar
cold start injector might not be working properly.
if it's really that cold, a 5w30 or even a 0w30 type oil might be a good idea
Old Dec 19, 2004 | 06:05 PM
TACOMANATOR's Avatar
How old is your battery. If its a newer red top you should be fine. If it's a yellow top then that could be your problemwith the long slow turnover. Bad gas, or water in the fuel system?
Old Dec 20, 2004 | 06:56 AM
Mad Chemist's Avatar
Putting some dry gas in the tank, maybe some injector cleaner- it sounds like you're turning her over okay, but not getting much of a spark for ignition. Maybe even running slightly higher octane fuel.
Old Dec 20, 2004 | 07:52 AM
PirateFins's Avatar
I had the same problem this morning, so your not alone. Just cleaned out the fuel system with some Seafoam, so it's not water. It just didn't want to run, it seemed like there wasn't any lubing going on. I am going to switch to some lighter weight oil if it's going to help. once it got going finnaly it was fine.
Old Dec 20, 2004 | 08:01 AM
Marc's Avatar
5W-30 Oil, good battery, good state of tune and it should always start
whether it's plugged in or not
Old Dec 20, 2004 | 08:17 AM
4x4Lamm's Avatar
My Optima is a red top, made in January 2001. It was damaged once (minor) and repaired with epoxy.
Bad gas, maybe. Both times this has happened I have had a full tank...
I think I'll dump in some Iso HEET.
As far as the cold start injector, that is kindof like a choke right. I would think that pumping the gas would solve the problem of it not working properly. Maybe?
Any other ideas?
Thanks,
Lamm
Old Dec 20, 2004 | 08:31 AM
TacomaTRD's Avatar
Any other ideas?
Thanks,
Lamm
Your 4runner is fuel injected, no choke, that is taken care of from the cold start injector. for fuel injected engines you shouldn't need to pump the throttle, in fact IM experience you don't want to pump it...
Old Dec 20, 2004 | 09:23 AM
Fink's Avatar
Hey Lamm,
I had this problem about a year ago and it turned out to be a cut cold start injector wire but I patched it up and it starts right up everytime now. And you're right about the CSI, all it does is add a little more fuel when the engine is cold to make it start up easier...if you need pics I can try and dig mine up, or I can go out and take some more.
Good luck man!
Fink
Old Dec 20, 2004 | 12:12 PM
BOSTON4RUNNER's Avatar
Any ideas? Help...
Thanks,
Lamm
def maybe a cold start injector thingy
your truck shouldnt have a problem starting
in new england, last winter we had a week of below zero weather, never had a problem with my truck
Old Dec 20, 2004 | 12:20 PM
lee's Avatar
lee
i definitely remember that one!
my runner was brand new to me then, and i was loving it starting right up every morning when it was -5.
Old Dec 20, 2004 | 01:06 PM
4x4Lamm's Avatar
Originally Posted by 4x4Fink
Hey Lamm,
Good luck man!
Fink
A pic or two would be awsome. God knows I have thrashed my 4Runner around so much, a cut/broken wire is a real posibility.
Thanks, and when are you gettin a winch Fink?
Lamm
Old Dec 20, 2004 | 01:10 PM
Fink's Avatar
I'll try and get some pics...its gettin dark now so it'll probably be tomorrow before I can get some.
The winch should be comin soon...keep your fingers crossed, donations are always welcome!
Fink
Old Dec 20, 2004 | 01:15 PM
VolcomTacoma's Avatar
Are you using synthetic oil? One of its best benefits over conventional oil is use in temperature extremes. Don't know if synthetic will solve your cold weather starting problem, but it can only help.
Old Dec 20, 2004 | 01:17 PM
toyota_s_runner's Avatar
I know when it's going to be real cold I try to park it in such a way it keeps the wind from blowing right into the grill. 8 hours of 30mph winds @ 10 below isn't good for anything. So that means I keep it off the street and park it tight to the garage or nose to nose with another one of my trucks
Old Dec 20, 2004 | 01:25 PM
4x4Lamm's Avatar
Whenever you get some time Fink, thanks.
I run a sythetic blend. I'm a little afraid that after 200,000 plus miles, a switch to synthetic will create some leaks.
Lamm
Old Dec 20, 2004 | 02:53 PM
kyle_22r's Avatar
higher octane gas is harder to "set off" so i can't imagine that it would help in colder weather
Old Dec 20, 2004 | 03:10 PM
Paul H.'s Avatar
Wind chill will not effect a none living thing, only true temperature will.
Old Dec 20, 2004 | 05:44 PM
4RUNR's Avatar
Guest
Is there some winter mix differential oil? Anything below 0 and it feels like towing a 500lb trailer. Doesn't warm up if not driving too fast either.
Old Dec 27, 2004 | 07:38 AM
4x4Lamm's Avatar
Well, I feel like an idiot. It turned out to be a bad Optima. I got a new one with some
x-mas cash. Works fine so far.
Lamm
kawazx636
Oct 6, 2021 03:03 PM
ocfatman
Aug 24, 2015 06:24 AM
taller1
Jul 16, 2015 03:00 PM
