RevTek lift installed..questions..
Old Jan 30, 2003 | 05:59 PM
PhxTRDRunner's Avatar
I just installed the 3 inch lift from Revtek, looks great. But, I am curious to those of you out there that have this lift, is it supposed to make some "clunking" noises up front? I can feel it in my feet a little...and I'm wondering if it just needs to "settle in" to stop it? I did the install exactly to instructions, but it is a little noisy. Is this normal? Everything is tight, I have checked and re-checked everything! Please, any input appreciated
Old Jan 30, 2003 | 06:24 PM
Mojo_Risin's Avatar
When exactly does it "clunk"? Over bumps? Coming to a stop?
I had the Revtek for about 2 years and can't say I ever heard a clunking noise (at least that I associated with the lift)
John
Old Jan 30, 2003 | 06:31 PM
When going over even the smallest bumps...
Old Jan 30, 2003 | 07:05 PM
Mojo_Risin's Avatar
Does it seem to come more from the drivers side? Is it when the tire goes up over the bump or back down over a bump?
I know that when you put the spacer lift in you basically lose that 2-3" of downtravel that you gain in lift. Which basically means there isn't much downtravel left when you hit a bump. I would really notice it when going over speedbumps. Hitting the bump was fine but when the tires dropped back down off of the bump-a sort of "clunk" would happen when the suspension reached it's full droop. However, when you say the"smallest" bumps, I'm not sure what that means so this may not be the case at all. When you jack up the front end from under the front diff, how much can you jack it up before the front tires come off the ground? If it isn't much at all then you are basically driving at full droop - which doesn't leave much dpwntravel for when you hit a pot hole or something. This usually make for a bit "stiffer" ride and not necessarily a "clunk".
I don't know - just throwing things out there.
John
John
Old Jan 30, 2003 | 07:11 PM
RTdawgs's Avatar
doesnt sound good. you make sure everything is bolted back up tightly?
Old Jan 30, 2003 | 07:43 PM
Well, I went out and checked again, and yes, everything is tight. It makes the noise over ANY bump, and I mean anything. Even a manhole cover makes it do it. Both sides seem to have the same sound....so I"m wondering if I didn't put the spacer in right? If that is even possible?
Old Jan 30, 2003 | 07:54 PM
azrain's Avatar
Did it come with the diff drop kit?
I haven't done this kit, but email or PM me and maybe we can hook up to take a look at it.
Mike
Old Jan 30, 2003 | 10:21 PM
*Update*
Ok, yes I am a moron. When I read "discard rubber spacer", I kind of took that to be the round rubber spacer on the top of the whole assembly. DO NOT DO THIS!! You need this, as it provides much more pressure for the entire assembly.
Problem solved.
Thanks to everyone for their advice ~ extreme offroad thanks again!
..how those skid plates coming along?
~ and thanks to AZRAIN for the offer I'm actually quite knowledgeable in wiring if you ever need any help.
Old Jan 31, 2003 | 05:03 AM
SLC Punk's Avatar
I am glad you got it fixed
We want pics!
Old Feb 2, 2003 | 09:59 AM
monkeynuts's Avatar
i have the same lift sitting in my office waiting for me to get off my a$$ and install it. did it even out your truck, or is one end higher than the other. also, how are your cv angles after the install? i have the same year 4runner and i am kind of worried about the boots.
Old Feb 2, 2003 | 10:38 AM
XtremeOff-Road's Avatar
Glad everything worked out for you bud!!!
Mike
Old Feb 2, 2003 | 08:24 PM
Monkeynuts ~ worked out pretty dang even. I am very pleased with the outcome. The 285's really make the big difference overall....the angles are a bit severe, but I"m not too worried about it, IF they do go out, they don't look to hard to change. From what I've read, I haven't found anyone to have problems with them, so I'm sure it'll be ok.
Xtreme ~ I just gotta learn a bit more about 4runners so I don't have to keep calling you for help!
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
