Old Apr 12, 2016, 07:51 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Cooling System Guides
Print Wikipost
Replacing thermostat
Old Aug 12, 2005 | 04:29 PM
fo_runner's Avatar
I'm gonna be buying a new thermostat tommarow, because of my overheating problems; and I wanted to ask you guys if I am able to replace the thermostat easily without a PITA. And what tools and materials will I need to replace it?
I might change the radiator too, since I never changed it since my dad bought the truck brand new.
Old Aug 12, 2005 | 04:41 PM
nunsa's Avatar
The T-stat is a Piece of cake , no sh**! 2 10mm nuts, whalla! Either upgrade to a HP T-stat or go with an OEM. If you go with an OEM cut that damn nipple off, of all my experience if you go with a cheap aftermarket the SOB will overheat on you! The rad, really isn't that bad either, take the fan clutch,fan and shroud off to make it a hell of a lot easier!
Take Care!
Old Aug 12, 2005 | 06:35 PM
freshman's Avatar
not to hijack but can you please post a pic to where it is located? Thanks. 2nd gen 4runner.
Old Aug 12, 2005 | 06:36 PM
fo_runner's Avatar
How about the gasket for the thermostat housing, how do I replace it? Or do i reuse the old one?
Old Aug 12, 2005 | 06:38 PM
fo_runner's Avatar
Freshman, its on the bottom of the engine, where the lower radiator hose leads into the engine. Right behind the radiotor fan.
rimpainter.com's Avatar
Replace it. They are like $2 at NAPA or similar. It simply goes around the new thermo like a big o-ring. At least that's how it is on the 5VZ - I assume the 3VZ is the same way.
Old Mar 4, 2006 | 12:36 PM
Amocat00's Avatar
My engine has been overheating, so I took out the thermostat. I can't tell if it's sticking or not. I'll probably buy a new one tomorrow. Would it hurt to run it w/o the thermostat until I replace it?
Thanks,
~Shawn
Old Mar 4, 2006 | 12:42 PM
Amocat00's Avatar
Thanks,
~Shawn
Nevermind, I let it sit running while I came up here and checked in to the thermostat, and it's still overheating. Back to the drawing board...
~S
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
Poncho0206
Jul 10, 2015 06:21 PM
