replacing shocks on a 3rd gen
Old Jul 28, 2005 | 02:36 PM
northfacer581's Avatar
so the 4runner has 117k on it with stock shocks, a 3" revtek and 2" 4crawler lift wth 33" maxxis mudders on it. at highway speeds theres a pretty big vibration problem, and im almost positive its due to the shocks.
the question arises as to which shocks to put in. as ive read on here, and looked around at stores, i think theres a few choices ive narrowed it to:
-bilsteins
-ome
the ? is for anything anyone here suggests. ride comfort isnt an issue; i do wheel it quite often, so its seeing a good amount of the offroad (lots of trails with hills and testing the suspension quite a bit). so obviously im looking for something very strong and durable for offroad. are there any shocks that can give me any more lift than what ive got? price isnt really an object. thanks for any input.
Old Jul 28, 2005 | 02:38 PM
bamachem's Avatar
OME are the best - bar none.
Old Jul 28, 2005 | 07:43 PM
they wont give me any lift will they?
Old Jul 28, 2005 | 07:52 PM
calg3's Avatar
No, the springs (or spacers) give you the lift not the shocks.
Old Jul 28, 2005 | 08:16 PM
ive got a revtek 3" suspension lift...is there any way to gain more lift out of it with ome setup?
Old Jul 28, 2005 | 10:03 PM
montypower's Avatar
I second that... I have the OME N86 and it rides great.
Old Jul 29, 2005 | 04:09 AM
bamachem's Avatar
no, and w/ the IFS, you don't want to go any higher.
get a body lift from 4crawler.com - 1", 1.5", 2"...
Old Jul 29, 2005 | 06:00 AM
sschaefer3's Avatar
I really like my Bilstein 5150 resivoir shocks. But then again those take some very minor modifications to install.
For bolt on shocks, the Old Man Emu seem to be the best and here is why. The front shock has a huge massive shaft like the Sway-A-Way or other high end coil-overs. The rear shock is the longest you can run without destroying your rear sway bar or completely impacting your gas tank on full drivers side stuff.
FWIW, the HD OME shocks are softer than your stock shocks, so what ever you do, get the Heavy Duty models, they are not really heavy duty in the sence you would think.
Old Jul 29, 2005 | 08:01 AM
yea i got the 2" from 4crawler. i think im going to go with the ome since theyre just bolt on and ive heard great things about them. i was pretty sure no shock could give me any lift, i just was on the 4wheelparts site, and they had these rancho shocks that said "these shocks do not raise or lower your vehicle" so i figured there might be some out there that do. thanks for the input and not bashing me on that thought...im only 17
Old Jul 29, 2005 | 09:13 AM
bamachem's Avatar
in the front, if the spring perch is higher on the shock base, then it could give you a lift, but that's the only way...
Old Jul 29, 2005 | 09:28 AM
well i think im just going to order the ome shocks front and rear. up front im going to go with the n91s and in the back the n86. hopefully it will be an easy install.
Old Jul 29, 2005 | 10:42 AM
bamachem's Avatar
the guys at http://www.wheelersoffroad.com are good people to work with and have good pricing...
Old Jul 29, 2005 | 01:38 PM
yeap ive been talking with them, looks like its the place to go for ome stuff.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
tpd143
Jul 7, 2015 09:06 AM
Steezy96yota
Jul 6, 2015 10:00 AM
coryc85
Jul 6, 2015 04:07 AM
