Replaced my starter. WHAT A JOB!
Well, Saturday morning, I got up early and started working on replacing the starter. It started off okay (so I thought) and then got bad and then got better. First I removed the wheel, looked for the starter, then realized I removed the wrong wheel.
Feeling like a dumba$$, I put the wheel back on and moved to the other side. :confused:
Long story short, if you have Edelbrock headers, it will be nearly impossible to remove the starter unless you remove the passenger side collector. A 2 hour job turned into 6.
Feeling like a dumba$$, I put the wheel back on and moved to the other side. :confused: Long story short, if you have Edelbrock headers, it will be nearly impossible to remove the starter unless you remove the passenger side collector. A 2 hour job turned into 6.
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
