Removing rear shocks
Old Mar 22, 2004 | 04:26 PM
AJatx's Avatar
So how many times do you hit the top nut of the rear shock (3rd gen 4Runner) with WD-40 or some water dispersant?
I'm also spraying it everywhere since I don't have much visibility, even with the spare out.
I've been spraying mine everyday for about 3 days and it still won't break open.
The strap wrench I used crushed the shock hat a little. Unfortunately, my buddy has some oil in the strap.
The El Cheapo air socket wrench didn't work either.
Do I need to resort to use vice grips or cut the shock out?
Maybe I need to start working out?
J
Old Mar 22, 2004 | 07:10 PM
White SR5's Avatar
Method
Here's a helpful method I tried, and it worked. Take one of your longer wrenches or ratchets, stick it on the nut, and then with your hands turn the actual shock part until the wrench presses up against one of the things sticking down where the mount is. Then once it is pressed up against that, twist the shock with your hands (and make sure you do it in the right direction!). That's the only way that worked for me. It's just in such an awkward place for your to get any decent leverage. Let me know if it works!
Zach
Old Mar 23, 2004 | 10:12 PM
lanai's Avatar
I did exactly what Zach did except that I used one of those strap wrenches that you can get from Checkers for about $5 and it worked out fine.
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:34 PM
ItsJustD
Jul 7, 2015 07:49 AM
